The following examples show you how to use the KcsFile class.
This example shows you how to read a file from a specified offset with absRead(). See the kcsio.h header file for a description of absRead().
KcsStatus readIt()
KcsStatus sStatus;
KcsFileId sFileRef;
long index = 32;
long number;
// open the file, put the fileRef into sFileRef
sFileRef = open ("Profile", O_RDWR);
if (sFileRef == -1)
return (KCS_IO_ERROR);
// create a file object
file = new KcsFile(&sStatus, sFileRef, 0);
if (sStatus != KCS_SUCCESS)
return(sStatus);
// using the file object, read from the file into a buffer.
sStatus = file->absRead(index, sizeof(long), &number);
delete file;
close(sFileRef);
return (sStatus);
This example shows you how to write to a file with relWrite(). See Table 2-3 for a full definition of relWrite().
KcsStatus writeIt()
KcsStatus sStatus;
KcsFileId sFileRef;
long nbytes;
char *buffer;
// open the file, get a fileRef
if (sFileRef == -1)
file = new KcsFile(&sStatus, sFileRef);
return(sStatus);
// Allocate memory for the buffer, fill it with data.
// Set nbytes to the length of the buffer.
if ((buffer = (char*) malloc(nbytes)) == NULL)
delete file;
close(sFileRef);
// using the file object, write the buffer to the file.
sStatus = file->relWrite(nbytes, buffer);
// Free the buffer's memory.
free (buffer);
delete file;
close(sFileRef);
return (sStatus);
