Typically you create a KcsXform class derivative when you create a CMM. The KcsXform is the most common derivative, since most color management suppliers have their own type of transformation technology. Most color technology involves manipulating matrixes and transforms. This class allows you to define a transform and its methods.
See Chapter 7, KcsXform Derivative for information on creating a KcsXform class derivative.
