If you extend the KcsStatus class, you need to provide a KcsStatus class entry such as the example below:
#Extending error messages
class="KCS_STAT" name-"solm"
kcsLoadableModule="kcsSUNWSTATsolm.so.1";
The name field is a 4-character string that uniquely identifies your set of error and warning messages.
To add your own error messages, supply a single "C" routine that translates your error value into an error string. Also supply a messages.po file for localization purposes. See Chapter 8, KcsStatus Extension for detailed information.
If an OwnerId variable is set with the status message, the KcsStatus class dynamically loads the matching OwnerId that was set by the dynamically loaded class. The OwnerID is described in Chapter 8, KcsStatus Extension.
