Once a KcsIO object has been created, the profile can be loaded. Figure 3-4 illustrates creating a KcsProfile object.
In Figure 3-4, the first step to loading the profile is to create a new KcsProfile object with the createProfile() static KcsProfile method. This method uses the CMM Id of the profile, which is located in a fixed place (bytes 4-7) in the profile header. (See "ICC Profile Header" for details.) The CMM Id determines the KcsProfile derivative to be created. If the CMM Id has no corresponding entry in the OWconfig file, the default KcsProfile class is created.
