In the next example, the framework loads a profile associated with a particular X11 Window System visual. The KcsXWindow object converts the display, visual, and screen information into a profile loaded into the KCMS framework. Example 3-3 is a KCMS "C" API code excerpt that shows this.
if ((dpy = XOpenDisplay(hostname)) == NULL) {
fprintf(stderr, "Couldn't open the X display \n");
exit(1);
profileDesc.type = KcsWindowProfile;
profileDesc.desc.xwin.dpy = dpy;
profileDesc.desc.xwin.visual = DefaultVisual(dpy,
DefaultScreen(dpy));
profileDesc.desc.xwin.screen = DefaultScreen(dpy);
status = KcsLoadProfile(&profile, &profileDesc,
KcsLoadAttributesNow);
if (status != KCS_SUCCESS) {
status = KcsGetLastError(&errDesc);
fprintf(stderr,"KcsLoadProfile failed error = %s\n",
errDesc.desc);
exit(1);
The only difference between this example and Example 3-2, is the type of KcsIO class loaded. That example showed how to load a KcsSolarisFile object rather than a KcsXWindow object.
