The load() method can take a loadhint with multiple bits set. The following error protocols are used:
If the only error the derivative receives during load is KCS_PFMT_NO_DATA_SUPPORT_4_REQUEST and everything loads successfully, return KCS_SUCCESS.
Say, for example, you ask for a forward complete and the derivative also tries to load the reverse complete (for optimization). If the reverse receives an error but forward succeeds, KCS_SUCCESS is returned.
If nothing requested is available, return KCS_PFMT_NO_DATA_SUPPORT_4_REQUEST.
