The following example shows you how to use the entry points when creating a KcsXform derivative.
extern long KcsDLOpenXfrmCount = 0;
/* Global initialization */
KcsStatus
KcsInitXfrm(long libMajor, long libMinor, long *myMajor, long *myMinor)
// Set up the return values
*myMajor = KCS_MAJOR_VERSION;
*myMinor = KCS_MINOR_VERSION;
//Check the major version
if (libMajor != KCS_MAJOR_VERSION)
return (KCS_CMM_MAJOR_VERSION_MISMATCH);
//Currently, if minor version of library is less than the KCMS
// minor version, return < an error.
if (libMinor KCS_MINOR_VERSION)
return (KCS_CMM_MINOR_VERSION_MISMATCH);
//Library guarantees if your minor version number is greater than
//KCMS minor version number, it will handle it. No more init.
return(KCS_SUCCESS);
KcsXform * KcsCreateXfrm(KcsStatus *aStat, KcsChunkSet *aCS,
KcsChunkId aChunkId, KcsAttributeSet *aAttrSet)
//Create the new derivative
return(new KcsTechUCP(aStat, KcsLoadAllow, aCS, aChunkId,
aAttrSet));
/* Global clean up */
KcsStatus
KcsCleanupXfrm()
KcsStatus sStat;
