KCMS Test Suite User's Guide
Setting Up Your CMM
Guidelines for setting up your CMM are described in detail in the KCMS CMM Developer's Guide. To set up your CMM,
  1. Name your CMM according to the guidelines in Chapter 2, "CMM: A Runtime Derivative," in the KCMS CMM Developer's Guide. The section entitled "Configuration Requirements" explains what you need to know to load your CMM dynamically, including how to name it and how to update the OWconfig file.
  2. Install your CMM according to the guidelines in the same chapter and section referenced in step 1.
  3. Create and name the profile(s) for your CMM according to the guidelines in Chapter 2, "CMM: A Runtime Derivative," in the KCMS CMM Developer's Guide. The section entitled "Profiles" describes the ICC profile format and explains how to name profiles.
  4. Install the profile so the KCMS framework can find it by following the guidelines in the same chapter and section referenced in step 3. Also install those profiles you want to use in the test suite in the kcmstest/profiles directory (see "Installing Scripts and Profiles") or create a link to them.
