IC_evalmany.scr
IC_evalmany.scr evaluates many images, processing over 100 MB of image data.
This script demonstrates that the KCMS framework can successfully perform the EVAL: command repetitively. First the script loads several profiles, and the CONNECT: command is called to create forward, reverse, and simulate profiles. In all, this test performs 25 EVAL: calls, constituting the processing of over 100 MB of image data. The script does not save the resulting evaluated image.
For details on how to save the image, see "EVAL: Keywords and Values" (ImageOut= keyword). Be sure you have enough disk space to do so.
Each command is expected to return successfully.
