Table 3-13 presents the MODIFYLH: command keywords and their descriptions.
Table 3-13 MODIFYLH: Command Keywords|
Keyword |
Description |
Reference= |
Is the name that was assigned when the profiles were loaded, created, or connected. |
LoadHint= |
Defines the load hint that will be used to load the profile. This keyword has the values shown in Table 3-14. In the table, the keyword value is followed by the corresponding value set in the loadHints parameter passed to the KcsLoadProfile() functionn. A LoadHint= keyword can appear more than once in a single script file. Multiple load hints are logically OR'd together. |
Operation= |
Defines the operation load hint that will be used to connect the new profile. This keyword has the operation and content hint values shown in Table 3-15. In the table, the keyword value is followed by the corresponding value set in the loadHints parameter passed to the KcsLoadProfile() function. An Operation= keyword can appear more than once in a single script command. Multiple load hints are logically OR'd together. |
XStatus= |
The default expected status is KcsSuccess. If the script command is expected to complete successfully, the XStatus= keyword is not required. In cases where a script command is expected to return a non-success status, the keyword is followed by the corresponding expected, non-success status in hexadecimal format. |
Table 3-14 presents the MODIFYLH: command LoadHint= keyword values.
Table 3-14 MODIFYLH: Command LoadHint= Keyword Values|
Value |
Load Hint Set |
AllNow |
KcsLoadAllNow |
AllWhen |
KcsLoadAllWhenNeeded |
LoadAttr |
KcsLoadAttributeNow |
MinMem |
KcsLoadMinimalMemory |
PurgeMem |
KcsPurgeMemoryNow |
LoadWhenNever |
KcsLoadNever |
LoadWhenNow |
KcsLoadNow |
LoadWhenNeeded |
KcsLoadWhenNeeded |
LoadWhenIdle |
KcsLoadWhenIdle |
UnloadWhenNow |
KcsUnloadNow |
UnloadWhenFree |
KcsUnloadWhenFreed |
UnloadWhenNeeded |
KcsUnloadWhenNeeded |
UnloadAfter |
KcsUnloadAfterUse |
WhatAttr |
KcsAttributes |
WhatAll |
KcsAll |
WhatEffects |
KcsEffect |
Table 3-15 presents the MODIFYLH: command Operation= keyword values.
Table 3-15 MODIFYLH: Command Operation=Keyword Values|
Value |
Load Hint Set |
OpsAll |
KcsOpAll |
ContUnkn |
KcsContUnknown |
Graphics |
KcsContGraphics |
Image |
KcsContImage |
ColorMtrc |
KcsContColorimetric |
ContAll |
