Reference=
Is the name that was assigned when the profiles were loaded or created, with
the CONNECT: or CREATE: command.
Profile
Type=
Is the type of profile that is being updated. The acceptable types are
Print
Scan
Mon
Effect
Currently
only scanner and monitor profiles can be updated.
Operation=
Is the type of operation that is being attempted during the update. The acceptable
operations are
Characterization
Calibration
Both
CalInDataFile=
Is the data file name of the calibration input data. It is assumed that the
file is in the kcmstest/data directory.
CalOutDataFile=
Is the data file name of the calibration output data. It is assumed that the
CharInDataFile=
Is the data file name of the characterization input data. It is assumed that
the file is in the kcmstest/data
directory. This value can be NULL.
CharOutDataFile=
Is the data file name of the characterization output data. It is assumed that
XStatus=
The default expected status is KcsSuccess. If the
script command is expected to complete successfully, the XStatus= keyword is not required. In cases where a script command is expected
to return a non- success status, the XStatus= is followed
by the corresponding expected, non-success status in hexadecimal format.
