IC_conmany.scr
IC_conmany.scr performs many CONNECT: commands. It confirms that subsequent framework operations can be performed successfully.
This script demonstrates that the KCMS framework can connect many profiles in succession while the framework continues to operate without error. The script loads a variety of profiles (monitor, printer, scanner, Photo CD), and connects them with a variety of operation and content hints. On the profiles loaded, it performs 20 connect calls. With the 20 connected profiles in memory, it evaluates the complete profiles. It does not save the color-managed images. After the operations are completed, it frees the profiles from memory.
Each command is expected to return successfully.
