IC_evalerr.scr
IC_evalerr.scr attempts to create test conditions that cause the EVAL: command to return various errors.
This script demonstrates that the KCMS framework can perform a CONNECT: command under a variety of error conditions and return the appropriate error status. The script performs the CONNECT: command with the following error conditions:
It attempts to evaluate using a profile that is not complete.
It attempts to evaluate an image, specifying a transformation that is not part of the complete profile provided in the EVAL: command.
It attempts to evaluate an image, specifying a content hint that is not part of the complete profile provided in the EVAL: command.
Commands that are expected to fail will have the expected failure status provided as part of the EVAL: script command.
