IC_update1.scr
IC_update1.scr creates and updates a scanner profile with HP Scanjet calibration and characterization data. It connects the scanner profile with a monitor profile to create a complete profile. The complete profile is then used to evaluate an image. The resulting image is saved for post-test subjective evaluation.
This script demonstrates that the KCMS framework can create and update a scanner profile with calibration and characterization data. The data used will not necessarily match your scanner.
The test script verifies that, after the profile is updated, it can be connected to a monitor profile and the resulting profile used to evaluate images.
The script creates a scanner profile and sets several attributes after which it performs the UPDATE: command. Then it saves the updated profile and connects it to a monitor profile. It evaluates the test image using this complete profile. Then it frees the profiles from memory.
All the commands listed in this test are expected to complete successfully. You need to subjectively evaluate the image resulting from the EVAL: command.
