KCMS Test Suite User's Guide
IC_evalplus.scr
Concept
IC_evalplus.scr connects configured X Window System visual profiles to scanner and printer profiles and evaluates the profiles in the same manner as generic profiles.
Description
This script is similar to IC_eval.scr (see "Evaluate") with one exception: the monitor profile used is a configured/calibrated X Window System visual profile for the current frame buffer. This test should succeed if the system has been previously configured using the kcms_configure(1) or kcms_calibrate(1) command. After evaluation, the script frees the profiles from memory.
Verification
All the commands listed in this script are expected to complete successfully.
