IC_xwindow.scr:
Automatically accesses a profile that has been previously configured for the current frame buffer using the kcms_configure(1) or kcms_calibrate(1) commands
Accesses a Solaris profile across the network
This script demonstrates that the KCMS framework can access profiles locally and across the network. First it loads the default X Window System profile from the local host. Then it loads a Solaris profile from another host machine. Finally it frees the profiles from memory.
The kcms_server(1) daemon must be running on the remote most. If it is not running, type kcms_server in a command shell as root on the remote host.
All the commands are expected to complete successfully, provided the kcms_server(1) daemon is running on the current machine.
