This is a no-frills function for creating a transport connection with the client.
* Function: create_socket
* Purpose: Opens a listening TCP socket.
* Arguments:
* port (r) the port number on which to listen
* Returns: the listening socket file descriptor, or -1 on failure
* Effects:
* A listening socket on the specified port and created and returned.
* On error, an error message is displayed and -1 is returned.
int create_socket(port)
u_short port;
struct sockaddr_in saddr;
int s;
int on = 1;
saddr.sin_family = AF_INET;
saddr.sin_port = htons(port);
saddr.sin_addr.s_addr = INADDR_ANY;
if ((s = socket(AF_INET, SOCK_STREAM, 0)) < 0) {
perror("creating socket");
return -1;
/* Let the socket be reused right away */
(void) setsockopt(s, SOL_SOCKET, SO_REUSEADDR, (char *)&on,
sizeof(on));
if (bind(s, (struct sockaddr *) &saddr, sizeof(saddr)) < 0)
perror("binding socket");
(void) close(s);
return -1;
if (listen(s, 5) < 0) {
perror("listening on socket");
(void) close(s);
return -1;
return s;
