This is the entry point to the program. The program takes the following syntax on the command line:
gss-server [-port port] [-d] [-mech mech] host service msg |
After parsing the command line, main() converts the name of the desired security mechanism (if provided) to an OID, acquires credentials, establishes a context and receives data, and then destroys the mechanism OID if necessary.
Applications should normally not set the mechanism, but use defaults provided by the GSS-API.
int
main(argc, argv)
int argc;
char **argv;
char *service_name, *mechType = NULL;
gss_cred_id_t server_creds;
OM_uint32 min_stat;
u_short port = 4444;
int s;
int once = 0;
int do_inetd = 0;
log = stdout;
display_file = stdout;
argc--; argv++;
while (argc) {
if (strcmp(*argv, "-port") == 0) {
argc--; argv++;
if (!argc) usage();
port = atoi(*argv);
} else if (strcmp(*argv, "-verbose") == 0) {
verbose = 1;
} else if (strcmp(*argv, "-once") == 0) {
once = 1;
} else if (strcmp(*argv, "-inetd") == 0) {
do_inetd = 1;
} else if (strcmp(*argv, "-mech") == 0) {
argc--; argv++;
if (!argc) usage();
mechType = *argv;
} else if (strcmp(*argv, "-logfile") == 0) {
argc--; argv++;
if (!argc) usage();
log = fopen(*argv, "a");
display_file = log;
if (!log) {
perror(*argv);
exit(1);
} else
break;
argc--; argv++;
if (argc != 1)
usage();
if ((*argv)[0] == '-')
usage();
service_name = *argv;
if (mechType != NULL) {
if ((g_mechOid = createMechOid(mechType)) == NULL) {
usage();
exit(-1);
if (server_acquire_creds(service_name, g_mechOid, &server_creds) < 0)
return -1;
if (do_inetd) {
close(1);
close(2);
sign_server(0, server_creds);
close(0);
} else {
int stmp;
if ((stmp = create_socket(port))) {
do {
/* Accept a TCP connection */
if ((s = accept(stmp, NULL, 0)) < 0) {
perror("accepting connection");
} else {
/* this return value is not checked, because there's
not really anything to do if it fails */
sign_server(s, server_creds);
} while (!once);
close(stmp);
(void) gss_release_cred(&min_stat, &server_creds);
if (g_mechOid != GSS_C_NULL_OID)
gss_release_oid(&min_stat, &g_mechOid);
/*NOTREACHED*/
(void) close(s);
return 0;
