To make the client and server programs work as shown, a number of other functions are required. These are mostly for displaying values, and are not necessary to the basic functioning of the programs. They are shown here for completeness.
Two functions, however, are significant: send_token() and recv_token(), which do the actual transfer of context tokens and messages. They are actually plain “vanilla” functions that open up a file descriptor and read to or write from it. Although ordinary, and not directly related to the GSS-API, they are sufficiently important to call out separately.
These functions include:
display_status() — Shows the status returned by the last GSS-API function called.
write_all() — Writes a buffer to a file.
read_all() — Reads a file into a buffer.
display_ctx_flags() — Shows in a readable form information about the current context, such as whether confidentiality or mutual authentication is allowed.
print_token() — Prints out a token's value.
/* * Copyright 1994 by OpenVision Technologies, Inc. * * Permission to use, copy, modify, distribute, and sell this software * and its documentation for any purpose is hereby granted without fee, * provided that the above copyright notice appears in all copies and * that both that copyright notice and this permission notice appear in * supporting documentation, and that the name of OpenVision not be used * in advertising or publicity pertaining to distribution of the software * without specific, written prior permission. OpenVision makes no * representations about the suitability of this software for any * purpose. It is provided "as is" without express or implied warranty. * * OPENVISION DISCLAIMS ALL WARRANTIES WITH REGARD TO THIS SOFTWARE, * INCLUDING ALL IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS, IN NO * EVENT SHALL OPENVISION BE LIABLE FOR ANY SPECIAL, INDIRECT OR * CONSEQUENTIAL DAMAGES OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF * USE, DATA OR PROFITS, WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR * OTHER TORTIOUS ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE OR * PERFORMANCE OF THIS SOFTWARE. */ #if !defined(lint) && !defined(__CODECENTER__) static char *rcsid = "$Header: /afs/athena.mit.edu/astaff/project/krbdev/.cvsroot /src/appl/gss-sample/gss-misc.c,v 1.15 1996/07/22 20:21:20 marc Exp $"; #endif #include <stdio.h> #include <sys/types.h> #include <netinet/in.h> #include <errno.h> #ifdef HAVE_UNISTD_H #include <unistd.h> #endif #include <string.h> #include <gssapi/gssapi.h> #include "gss-misc.h" #include <stdlib.h> FILE *display_file; extern gss_OID g_mechOid; static void display_status_1(char *m, OM_uint32 code, int type); static int write_all(int fildes, char *buf, unsigned int nbyte) { int ret; char *ptr; for (ptr = buf; nbyte; ptr += ret, nbyte -= ret) { ret = write(fildes, ptr, nbyte); if (ret < 0) { if (errno == EINTR) continue; return(ret); } else if (ret == 0) { return(ptr-buf); } } return(ptr-buf); } static int read_all(int fildes, char *buf, unsigned int nbyte) { int ret; char *ptr; for (ptr = buf; nbyte; ptr += ret, nbyte -= ret) { ret = read(fildes, ptr, nbyte); if (ret < 0) { if (errno == EINTR) continue; return(ret); } else if (ret == 0) { return(ptr-buf); } } return(ptr-buf); } static void display_status_1(m, code, type) char *m; OM_uint32 code; int type; { OM_uint32 maj_stat, min_stat; gss_buffer_desc msg = GSS_C_EMPTY_BUFFER; OM_uint32 msg_ctx; msg_ctx = 0; while (1) { maj_stat = gss_display_status(&min_stat, code, type, g_mechOid, &msg_ctx, &msg); if (maj_stat != GSS_S_COMPLETE) { if (display_file) { fprintf(display_file, "error in gss_display_status" " called from <%s>\n", m); } break; } else if (display_file) fprintf(display_file, "GSS-API error %s: %s\n", m, (char *)msg.value); if (msg.length != 0) (void) gss_release_buffer(&min_stat, &msg); if (!msg_ctx) break; } } /* * Function: display_status * * Purpose: displays GSS-API messages * * Arguments: * * msg a string to be displayed with the message * maj_stat the GSS-API major status code * min_stat the GSS-API minor status code * * Effects: * * The GSS-API messages associated with maj_stat and min_stat are * displayed on stderr, each preceeded by "GSS-API error <msg>: " and * followed by a newline. */ void display_status(msg, maj_stat, min_stat) char *msg; OM_uint32 maj_stat; OM_uint32 min_stat; { display_status_1(msg, maj_stat, GSS_C_GSS_CODE); display_status_1(msg, min_stat, GSS_C_MECH_CODE); } /* * Function: display_ctx_flags * * Purpose: displays the flags returned by context initation in * a human-readable form * * Arguments: * * int ret_flags * * Effects: * * Strings corresponding to the context flags are printed on * stdout, preceded by "context flag: " and followed by a newline */ void display_ctx_flags(flags) OM_uint32 flags; { if (flags & GSS_C_DELEG_FLAG) fprintf(display_file, "context flag: GSS_C_DELEG_FLAG\n"); if (flags & GSS_C_MUTUAL_FLAG) fprintf(display_file, "context flag: GSS_C_MUTUAL_FLAG\n"); if (flags & GSS_C_REPLAY_FLAG) fprintf(display_file, "context flag: GSS_C_REPLAY_FLAG\n"); if (flags & GSS_C_SEQUENCE_FLAG) fprintf(display_file, "context flag: GSS_C_SEQUENCE_FLAG\n"); if (flags & GSS_C_CONF_FLAG ) fprintf(display_file, "context flag: GSS_C_CONF_FLAG \n"); if (flags & GSS_C_INTEG_FLAG ) fprintf(display_file, "context flag: GSS_C_INTEG_FLAG \n"); } void print_token(tok) gss_buffer_t tok; { int i; unsigned char *p = tok->value; if (!display_file) return; for (i=0; i < tok->length; i++, p++) { fprintf(display_file, "%02x ", *p); if ((i % 16) == 15) { fprintf(display_file, "\n"); } } fprintf(display_file, "\n"); fflush(display_file); }
These functions send and receive data between the client and the server. (In a multiprocess application they could do the same between processes.) They are slightly misnamed, since they send and receive messages as well as tokens. They are oblivious to the content they handle.
This function sends a token or message.
/* * Function: send_token * * Purpose: Writes a token to a file descriptor. * * Arguments: * * s (r) an open file descriptor * tok (r) the token to write * * Returns: 0 on success, -1 on failure * * Effects: * * send_token writes the token length (as a network long) and then the * token data to the file descriptor s. It returns 0 on success, and * -1 if an error occurs or if it could not write all the data. */ int send_token(s, tok) int s; gss_buffer_t tok; { int len, ret; len = htonl((OM_uint32)tok->length); ret = write_all(s, (char *) &len, sizeof(int)); if (ret < 0) { perror("sending token length"); return -1; } else if (ret != 4) { if (display_file) fprintf(display_file, "sending token length: %d of %d bytes written\n", ret, 4); return -1; } ret = write_all(s, tok->value, (OM_uint32)tok->length); if (ret < 0) { perror("sending token data"); return -1; } else if (ret != tok->length) { if (display_file) fprintf(display_file, "sending token data: %d of %d bytes written\n", ret, tok->length); return -1; } return 0; }
This function receives a token or message.
/* * Function: recv_token * * Purpose: Reads a token from a file descriptor. * * Arguments: * * s (r) an open file descriptor * tok (w) the read token * * Returns: 0 on success, -1 on failure * * Effects: * * recv_token reads the token length (as a network long), allocates * memory to hold the data, and then reads the token data from the * file descriptor s. It blocks to read the length and data, if * necessary. On a successful return, the token should be freed with * gss_release_buffer. It returns 0 on success, and -1 if an error * occurs or if it could not read all the data. */ int recv_token(s, tok) int s; gss_buffer_t tok; { int ret, len; ret = read_all(s, (char *) &len, sizeof(int)); if (ret < 0) { perror("reading token length"); return -1; } else if (ret != 4) { if (display_file) fprintf(display_file, "reading token length: %d of %d bytes read\n", ret, 4); return -1; } tok->length = ntohl(len); tok->value = (char *) malloc(tok->length); if (tok->value == NULL) { if (display_file) fprintf(display_file, "Out of memory allocating token data\n"); return -1; } ret = read_all(s, (char *) tok->value, (OM_uint32)tok->length); if (ret < 0) { perror("reading token data"); free(tok->value); return -1; } else if (ret != tok->length) { fprintf(stderr, "sending token data: %d of %d bytes written\n", ret, tok->length); free(tok->value); return -1; } return 0; }
