GSS-API Programming Guide
recv_token()
This function receives a token or message.
Example A–19 recv_token()
 * Function: recv_token
 * Purpose: Reads a token from a file descriptor.
 * Arguments:
 *      s               (r) an open file descriptor
 *      tok             (w) the read token
 * Returns: 0 on success, -1 on failure
 * Effects:
 * recv_token reads the token length (as a network long), allocates
 * memory to hold the data, and then reads the token data from the
 * file descriptor s.  It blocks to read the length and data, if
 * necessary.  On a successful return, the token should be freed with
 * gss_release_buffer.  It returns 0 on success, and -1 if an error
 * occurs or if it could not read all the data.
int recv_token(s, tok)
     int s;
     gss_buffer_t tok;
     int ret, len;
     ret = read_all(s, (char *) &len, sizeof(int));
     if (ret < 0) {
          perror("reading token length");
          return -1;
     } else if (ret != 4) {
         if (display_file)
             fprintf(display_file,
                     "reading token length: %d of %d bytes read\n",
                     ret, 4);
         return -1;
     tok->length = ntohl(len);
     tok->value = (char *) malloc(tok->length);
     if (tok->value == NULL) {
         if (display_file)
                     "Out of memory allocating token data\n");
          return -1;
     ret = read_all(s, (char *) tok->value, (OM_uint32)tok->length);
     if (ret < 0) {
          perror("reading token data");
          free(tok->value);
          return -1;
     } else if (ret != tok->length) {
          fprintf(stderr, "sending token data: %d of %d bytes written\n",
                  ret, tok->length);
          free(tok->value);
          return -1;
     return 0;
