Converts the name of the security mechanism provided on the command line (if any is provided) to an OID for GSS-API to work with.
Despite this sample, applications are strongly recommended to use the default mechanism provided by the GSS-API implementation, rather than specifying one. The default mechanism can be obtained by setting the mechanism OID value to GSS_C_NULL_OID. Also, the function gss_str_to_oid() is not supported by all GSS-API implementations.
static void parse_oid(char *mechanism, gss_OID *oid) { char *mechstr = 0, *cp; gss_buffer_desc tok; OM_uint32 maj_stat, min_stat; if (isdigit(mechanism[0])) { mechstr = malloc(strlen(mechanism)+5); if (!mechstr) { printf("Couldn't allocate mechanism scratch!\n"); return; } sprintf(mechstr, "{ %s }", mechanism); for (cp = mechstr; *cp; cp++) if (*cp == '.') *cp = ' '; tok.value = mechstr; } else tok.value = mechanism; tok.length = strlen(tok.value); maj_stat = gss_str_to_oid(&min_stat, &tok, oid); if (maj_stat != GSS_S_COMPLETE) { display_status("str_to_oid", maj_stat, min_stat); return; } if (mechstr) free(mechstr); }
