Input relocatable objects should be built from position-independent code. For example, the C compiler will generate position-independent code under the -K pic option. See "Position-Independent Code". Use the -z text option to enforce this requirement.
If the shared object is intended for external use, make sure it uses no application registers. Not using application registers provides the external user freedom to use these registers without fear of compromising the shared object's implementation. For example, the SPARC C compiler will not use application registers under the -xregs=no%appl option.
Establish the shared objects public interface by defining the global symbols that should be visible from the shared object, and reducing any other global symbols to local scope. This definition is provided by the -M option together with an associated mapfile. See Appendix B, Versioning Quick Reference.
Use a versioned name for the shared object to allow for future upgrades. See "Coordination of Versioned Filenames".
Self-contained shared objects offer maximum flexibility. They are produced when the object expresses all dependency needs. Use the -z defs to enforce this self containment. See "Generating a Shared Object Output File".
Avoid unneeded dependencies. Use ldd with the -u option to detect and remove unneeded dependencies. See "Shared Object Processing". Or, use the -z ignore option, which instructs the link-editor to record dependencies only to objects that are referenced.
If the shared object being generated has dependencies on other shared objects, indicate they should be lazily loaded using the -z lazyload option. See "Lazy Loading of Dynamic Dependencies".
If the shared object being generated has dependencies on other shared objects, and these dependencies do not reside in /usr/lib for 32-bit objects, or /usr/lib/64 for 64-bit objects, record their path name in the output file using the -R option. See "Shared Objects With Dependencies".
Optimize relocation processing by combining relocation sections into a single .SUNW_reloc section. Use the -z combreloc option.
If interposing symbols will not be used on this object or its dependencies, establish direct binding information with -B direct. See "External Bindings".
The following example combines the above points:
$ cc -c -o foo.o -Kpic -xregs=no%appl foo.c $ cc -M mapfile -G -o libfoo.so.1 -z text -z defs -B direct -z lazyload \ -z combreloc -z ignore -R /home/lib foo.o -L. -lbar -lc |
If the shared object being generated will be used as input to another link-edit, record within it the shared object's runtime name using the -h option. See "Recording a Shared Object Name".
Make the shared object available to the compilation environment by creating a file system link to a non-versioned shared object name. See "Coordination of Versioned Filenames".
$ cc -M mapfile -G -o libfoo.so.1 -z text -z defs -B direct -z lazyload \ -z combreloc -z ignore -R /home/lib -h libfoo.so.1 foo.o -L. -lbar -lc $ ln -s libfoo.so.1 libfoo.so |
Consider the performance implications of the shared object: Maximize shareability, as described in"Maximizing Shareability": Minimize paging activity, as described in "Minimizing Paging Activity": Reduce relocation overhead, especially by minimizing symbolic relocations, as described in "Reducing Symbol Scope": Allow access to data via functional interfaces, as described in "Copy Relocations".
