Another issue related to dependency location is how to establish a model whereby one unbundled product might have dependencies on the shared objects of another unbundled product.
For example, the unbundled product XYZ might have dependencies on the product ABC. This dependency can be established by a host package installation script that generates a symbolic link to the installation point of the ABC product, as shown in the following figure.
The binaries and shared objects of the XYZ product can represent their dependencies on the ABC product using the symbolic link as a stable reference point. For the application xyz, this runpath would be:
% dump -Lv xyz [1] NEEDED libX.so.1 [2] NEEDED libA.so.1 [3] RUNPATH $ORIGIN/../lib:$ORIGIN/../ABC/lib |
and similarly for the dependency libX.so.1 this runpath would be:
% dump -Lv libX.so.1 [1] NEEDED libY.so.1 [2] NEEDED libC.so.1 [3] RUNPATH $ORIGIN:$ORIGIN/../ABC/lib |
If this product is now installed under /usr/local/XYZ, its post-install script would be required to establish a symbolic link of:
% ln -s ../ABC /usr/local/XYZ/ABC |
If the user's PATH is augmented with /usr/local/XYZ/bin, then invocation of the application xyz will result in a path-name lookup for its dependencies as follows:
% ldd -s xyz ..... find object=libX.so.1; required by xyz search path=$ORIGIN/../lib:$ORIGIN/../ABC/lib (RPATH from file xyz) trying path=/usr/local/XYZ/lib/libX.so.1 libX.so.1 => /usr/local/XYZ/lib/libX.so.1 find object=libA.so.1; required by xyz search path=$ORIGIN/../lib:$ORIGIN/../ABC/lib (RPATH from file xyz) trying path=/usr/local/XYZ/lib/libA.so.1 trying path=/usr/local/ABC/lib/libA.so.1 libA.so.1 => /usr/local/ABC/lib/libA.so.1 find object=libY.so.1; required by /usr/local/XYZ/lib/libX.so.1 search path=$ORIGIN:$ORIGIN/../ABC/lib \ (RPATH from file /usr/local/XYZ/lib/libX.so.1) trying path=/usr/local/XYZ/lib/libY.so.1 libY.so.1 => /usr/local/XYZ/lib/libY.so.1 find object=libC.so.1; required by /usr/local/XYZ/lib/libX.so.1 search path=$ORIGIN:$ORIGIN/../ABC/lib \ (RPATH from file /usr/local/XYZ/lib/libX.so.1) trying path=/usr/local/XYZ/lib/libC.so.1 trying path=/usr/local/ABC/lib/libC.so.1 libC.so.1 => /usr/local/ABC/lib/libC.so.1 find object=libB.so.1; required by /usr/local/ABC/lib/libA.so.1 search path=$ORIGIN (RPATH from file /usr/local/ABC/lib/libA.so.1) trying path=/usr/local/ABC/lib/libB.so.1 libB.so.1 => /usr/local/ABC/lib/libB.so.1 |
