ONC+ Developer's Guide
AUTH_KERB Authentication
SunOS 5.0 and compatible versions include support for most client-side features of Kerberos 5 except klogin. AUTH_KERB is conceptually similar to AUTH_DES. The essential difference is that DES passes a network name and a DES-encrypted session key, while Kerberos passes the encrypted service ticket. This section describes other factors that affect implementation and interoperability.
Kerberos uses the concept of a time window in which its credentials are valid. It does not place restrictions on the clocks of the client or server. Specifically, the window is passed as an argument to authkerb_seccreate(). The window does not change. If a timehost is specified as an argument, the client side gets the time from the timehost and alters its timestamp by the difference in time. Various methods of time synchronization are available. See the kerberos_rpc man page for more information.
Kerberos users are identified by a primary name, instance, and realm. The RPC authentication code ignores the realm and instance, while the Kerberos library code does not. The assumption is that user names are the same between client and server. This enables a server to translate a primary name into user identification information. Two forms of well-known names are used (omitting the realm):
Kerberos uses cipher block chaining (CBC) mode when sending a full name credential, one that includes the ticket and window, and electronic code book (ECB) mode otherwise. CBC and ECB are two methods of DES encryption. The session key is used as the initial input vector for CBC mode. The following notation means that XDR is used on object as a type.
xdr_type(object)
The length in the next code section is the size, in bytes of the credential or verifier, rounded up to 4-byte units. The full name credential and verifier are obtained as follows:
xdr_long(timestamp.seconds)
xdr_long(timestamp.useconds)
xdr_long(window)
xdr_long(window - 1)
After encryption with CBC with input vector equal to the session key, the output is two DES cipher blocks:
CB0
CB1.low
CB1.high
The credential is:
xdr_long(AUTH_KERB)
xdr_long(length)
xdr_enum(AKN_FULLNAME)
xdr_bytes(ticket)
xdr_opaque(CB1.high)
The verifier is:
xdr_long(AUTH_KERB)
xdr_long(length)
xdr_opaque(CB0)
xdr_opaque(CB1.low)
The nickname exchange yields:
The nickname is encrypted with ECB to obtain ECB0, and the credential is:
xdr_long(AUTH_KERB)
xdr_long(length)
xdr_enum(AKN_NICKNAME)
xdr_opaque(akc_nickname)
The verifier is:
xdr_long(AUTH_KERB)
xdr_long(length)
xdr_opaque(ECB0)
xdr_opaque(0)
