ONC+ Developer's Guide
Appendix D RPC Code Examples
This appendix contains copies of the complete live code modules used in the rpcgen and RPC chapters of this book. They are compilable as they are written and will run, unless otherwise noted to be pseudo-code or the like. These examples are provided for informational purposes only. Sun Microsystems assumes no liability from their use.
Directory Listing Program and Support Routines (rpcgen)
Example D–1 rpcgen Program: dir.x
 * 	dir.x: Remote directory listing
 *	protocol
 *	This source module is a rpcgen source module
 *	used to demonstrate the functions of the rpcgen
 *	tool.
 *	It is compiled with the rpcgen -h -T switches to
 *	generate both the header (.h) file and the
 *	accompanying data structures.
const MAXNAMELEN = 255;	/*maxlengthofadirectoryentry*/
typedef string nametype<MAXNAMELEN>; /* directory entry */
typedef struct namenode *namelist;   /*linkinthelisting*/
 * A node in the directory listing
struct namenode {
 	nametype name;       /* name of directory entry */
 	namelist next;       /* next entry */
 * The result of a READDIR operation:
 *	a truly portable application would use an agreed upon list of
 *	error codes rather than, as this sample program does, rely
upon
 *	passing UNIX errno's back. In this example the union is used
to
 *	 discriminate between successful and unsuccessful remote
calls.
union readdir_res switch (int errno) {
	case 0:
		namelist list; /*no error: return directory listing*/
	default:
		void;      /*error occurred: nothing else to return*/
 * The directory program definition
program DIRPROG {
 	version DIRVERS {
 		readdir_res
 		READDIR(nametype) = 1;
 	} = 1;
 } = 0x20000076;
Example D–2 Remote dir_proc.c
 * dir_proc.c: remote readdir implementation
#include <rpc/rpc.h>      /* Always needed */
#include <dirent.h>
#include "dir.h"          /* Created by rpcgen */
extern int errno;
extern char *malloc();
extern char *strdup();
/* ARGSUSED1*/
readdir_res *
readdir_1(dirname,req)
 	nametype *dirname;
 	struct svc_req *req;
 	DIR *dirp;
 	struct dirent *d;
 	namelist nl;
 	namelist *nlp;
 	static readdir_res res; /* must be static! */
	 * Open directory
	dirp = opendir(*dirname);
	if (dirp == (DIR *)NULL) {
 		res.errno = errno;
 		return (&res);
	 * Free previous result
	xdr_free(xdr_readdir_res, &res);
	 * Collect directory entries. Memory allocated here is freed
by
	 * xdr_free the next time readdir_1 is called.
 	nlp = &res.readdir_res_u.list;
 	while (d = readdir(dirp)) {
 		nl = *nlp = (namenode *) malloc(sizeof(namenode));
 		if (nl == (namenode *) NULL) {
 			res.errno = EAGAIN;
 			closedir(dirp);
 			return(&res);
 		nl->name = strdup(d->d_name);
 		nlp = &nl->next;
 	*nlp = (namelist)NULL;
 	/* Return the result */
 	res.errno = 0;
 	closedir(dirp);
 	return (&res);
Example D–3 rls.c Client
 * rls.c: Remote directory listing client
#include <stdio.h>
#include <rpc/rpc.h>	/* always need this */
#include "dir.h"	    /* generated by rpcgen */
extern int errno;
main(argc, argv)
 	int argc;
 	char *argv[];
 	CLIENT *cl;
 	char *server;
 	char *dir;
 	readdir_res *result;
 	namelist nl;
	if (argc != 3) {
		fprintf(stderr, "usage: %s host directory\n",
		argv[0]);
		exit(1);
	server = argv[1];
	 dir = argv[2];
 * Create client "handle" used for calling MESSAGEPROG on the
server
 * designated on the command line.
	cl = clnt_create(server, DIRPROG, DIRVERS, "visible");
 	if (cl == (CLIENT *)NULL) {
 		clnt_pcreateerror(server);
 		exit(1);
 	result = readdir_1(&dir, cl);
 	if (result == (readdir_res *)NULL) {
 		clnt_perror(cl, server);
 		exit(1);
/* Okay, we successfully called the remote procedure. */
	if (result->errno != 0) {
	 * A remote system error occurred. Print error message and
die.
	if (result->errno < sys_nerr)
 		fprintf (stderr, "%s : %s\n", dir,
 		sys_enlist[result->errno]);
 		errno = result->errno;
 		perror(dir);
 		exit(1);
/* Successfully got a directory listing. Print it out. */
	for(nl = result->readdir_res_u.list; nl != NULL; nl = nl-
>next) {
		printf("%s\n", nl->name);
exit(0);
Time Server Program (rpcgen)
Example D–4 rpcgen Program: time.x
 * time.x: Remote time protocol
program TIMEPROG {
 	version TIMEVERS {
 			unsigned int TIMEGET(void) = 1;
 	} = 1;
} = 0x20000044;
#ifdef RPC_SVC
%int *
%timeget_1()
%	static int thetime;
%	thetime = time(0);
%	return (&thetime);
#endif
Add Two Numbers Program (rpcgen)
Example D–5 rpcgen program: Add Two Numbers
/* This program contains a procedure to add 2 numbers to
demonstrate
 * some of the features of the new rpcgen. Note that add() takes 2
 * arguments in this case.
program ADDPROG {			/* program number */
	version ADDVER {		/* version number */
		int add ( int, int )  	/* procedure */
			= 1;
	} = 1;
} = 199;
Spray Packets Program (rpcgen)
Refer to the notes section on the spray(1M) man page for information about using this tool.
Example D–6 rpcgen program: spray.x
 * Copyright (c) 1987, 1991 by Sun Microsystems, Inc.
/* from spray.x */
#ifdef RPC_HDR
#pragma ident "@(#)spray.h  1.2  91/09/17 SMI"
#endif
 * Spray a server with packets
 * Useful for testing flakiness of network interfaces
const SPRAYMAX = 8845;	/* max amount can spray */
 * GMT since 0:00, 1 January 1970
struct spraytimeval {
	unsigned int sec;
	unsigned int usec;
 * spray statistics
struct spraycumul {
	unsigned int counter;
	spraytimeval clock;
 * spray data
typedef opaque sprayarr<SPRAYMAX>;
program SPRAYPROG {
	version SPRAYVERS {
		 * Just throw away the data and increment the counter. This
		 * call never returns, so the client should always time it
out.
		void
		SPRAYPROC_SPRAY(sprayarr) = 1;
		 * Get the value of the counter and elapsed time since last
		 * CLEAR.
		spraycumul
		SPRAYPROC_GET(void) = 2;
		 * Clear the counter and reset the elapsed time
		void
		SPRAYPROC_CLEAR(void) = 3;
	} = 1;
} = 100012;
Print Message Program With Remote Version
Example D–7 printmesg.c
/* printmsg.c: print a message on the console */
#include <stdio.h>
main(argc, argv)
 	int argc;
 	char *argv[];
	char *message;
	if (argc != 2) {
		fprintf(stderr, "usage: %s <message>\n", argv[0]);
		exit(1);
	message = argv[1];
	if( !printmessage(message) ) {
		fprintf(stderr, "%s: couldn't print your message\n",
		        argv[0]);
		exit(1);
	printf("Message Delivered!\n");
	exit(0);
/* Print a message to the console. */
 * Return a boolean indicating whether the message was actually
 * printed.
printmessage(msg)
	char *msg;
	FILE *f;
	if = fopen("/dev/console","w");
		if (f == (FILE *)NULL)
			return (0);
	fprintf(f,"%sen”, msg);
	fclose(f);
	return (1);
Example D–8 Remote Version of printmesg.c
/*  * rprintmsg.c: remote version of "printmsg.c”  */
#include <stdio.h>
#include <rpc/rpc.h> /* always needed */
#include "msg.h”     /* msg.h generated by rpcgen */
main(argc, argv)
	int argc;
	char *argv[];
	CLIENT *cl;
	int *result;
	char *server;
	char *message;
	extern int sys_nerr;
	extern char *sys_errlist[];
	if (argc != 3) {
		fprintf(stderr,"usage: %s host messagen", argv[0]);
		exit(1);
	 * Save values of command line arguments
	server = argv[1];
	message = argv[2];
 * Create client"handle” used for calling
 * MESSAGEPROG on the server
	cl = clnt_create(server, MESSAGEPROG, PRINTMESSAGEVERS,
	                 "visible");
		 * Couldn't establish connection with server.
		 * Print error message and die.
		exit(1);
	/* Call the remote procedure "printmessage" on the server */
	result = printmessage_1(&message, cl);
	if (result == (int *)NULL) {
	 * An error occurred while calling the server.
		exit(1);
	if (*result == 0) {
		 * Server was unable to print our message.
		fprintf(stderr,"%s"
/* The message got printed on the server's console */
	printf("Message delivered to %s!\n", server);
	exit(0);
Example D–9 rpcgen Program: msg.x
/* msg.x: Remote message printing protocol */
program MESSAGEPROG {
 	version MESSAGEVERS {
 		int PRINTMESSAGE(string) = 1;
 	} = 1;
} = 0x20000001;
Example D–10 mesg_proc.c
 * msg_proc.c: implementation of the remote
 * procedure "printmessage"
#include <stdio.h>
 * Remote version of "printmessage"
/*ARGSUSED1*/
int printmessage_1(msg, req)
	char **msg;
	static int result; /* must be static! */
	FILE *f;
	f = fopen("/dev/console", "w");
	if (f == (FILE *)NULL) {
		result = 0;
		return (&result);
	fprintf(f, "%sen", *msg);
 	fclose(f);
 	result = 1;
 	return (&result);
Batched Code Example
Example D–11 Batched Client Program
#include <stdio.h>
#include "windows.h"
main(argc, argv)
	int             argc;
	char          **argv;
	struct timeval  total_timeout;
	register CLIENT *client;
	enum clnt_stat  clnt_stat;
	char            buf[1000], *s = buf;
	if ((client = clnt_create(argv[1], WINDOWPROG, WINDOWVERS,
	              "CIRCUIT_V")) == (CLIENT *) NULL) {
		clnt_pcreateerror("clnt_create");
		exit(1);
	timerclear(&total_timeout);
	while (scanf("%s", s) != EOF) {
		clnt_call(client, RENDERSTRING_BATCHED, xdr_wrapstring,
		  &s,xdr_void, (caddr_t) NULL, total_timeout);
	/* Now flush the pipeline */
	total_timeout.tv_sec = 20;
	clnt_stat = clnt_call(client, NULLPROC, xdr_void,
			 (caddr_t) NULL, xdr_void, (caddr_t) NULL,
total_timeout);
	if (clnt_stat != RPC_SUCCESS) {
		clnt_perror(client, "rpc");
		exit(1);
	clnt_destroy(client);
	exit(0);
Example D–12 Batched Server Program
#include <stdio.h>
void            windowdispatch();
main()
	int num;
	num = svc_create(windowdispatch, WINDOWPROG, WINDOWVERS,
	      "CIRCUIT_V");
	if (num == 0) {
		fprintf(stderr, "can't create an RPC server\n");
		exit(1);
	svc_run();                       /* Never returns */
	fprintf(stderr, "should never reach this point\n");
void
windowdispatch(rqstp, transp)
	struct svc_req *rqstp;
	SVCXPRT        *transp;
	char           *s = NULL;
	switch (rqstp->rq_proc) {
		case NULLPROC:
			if (!svc_sendreply(transp, xdr_void, 0))
				fprintf(stderr, "can't reply to RPC call\n");
			return;
		case RENDERSTRING:
			if (!svc_getargs(transp, xdr_wrapstring, &s)) {
				fprintf(stderr, "can't decode arguments\n");
				/* Tell caller an error occurred */
				svcerr_decode(transp);
				break;
			/* Code here to render the string s */
			if (!svc_sendreply(transp, xdr_void, (caddr_t) NULL))
			break;
		case RENDERSTRING_BATCHED:
				/* Be silent in the face of protocol errors */
				break;
			/* Code here to render string s, but send no reply! */
			break;
		default:
			svcerr_noproc(transp);
			return;
	/* Now free string allocated while decoding arguments */
	svc_freeargs(transp, xdr_wrapstring, &s);
Non-Batched Example
This example is included for reference only. It is a version of the batched client string rendering service, written as a non-batched program.
Example D–13 Unbatched Version of Batched Client
#include <stdio.h>
main(argc, argv)
	int             argc;
	char          **argv;
		exit(1);
	total_timeout.tv_usec = 0;
		if(clnt_call(client, RENDERSTRING, xdr_wrapstring, &s,
		    xdr_void, (caddr_t) NULL, total_timeout) != RPC_SUCCESS) {
			exit(1);
	exit(0);}
