ONC+ Developer's Guide
Spray Packets Program (rpcgen)
Refer to the notes section on the spray(1M) man page for information about using this tool.
Example D–6 rpcgen program: spray.x
 * Copyright (c) 1987, 1991 by Sun Microsystems, Inc.
/* from spray.x */
#ifdef RPC_HDR
#pragma ident "@(#)spray.h  1.2  91/09/17 SMI"
#endif
 * Spray a server with packets
 * Useful for testing flakiness of network interfaces
const SPRAYMAX = 8845;	/* max amount can spray */
 * GMT since 0:00, 1 January 1970
struct spraytimeval {
	unsigned int sec;
	unsigned int usec;
 * spray statistics
struct spraycumul {
	unsigned int counter;
	spraytimeval clock;
 * spray data
typedef opaque sprayarr<SPRAYMAX>;
program SPRAYPROG {
	version SPRAYVERS {
		 * Just throw away the data and increment the counter. This
		 * call never returns, so the client should always time it
out.
		void
		SPRAYPROC_SPRAY(sprayarr) = 1;
		 * Get the value of the counter and elapsed time since last
		 * CLEAR.
		spraycumul
		SPRAYPROC_GET(void) = 2;
		 * Clear the counter and reset the elapsed time
		void
		SPRAYPROC_CLEAR(void) = 3;
	} = 1;
} = 100012;
