nis_names()
Locates and manipulates objects.
nis_lookup()
Returns a copy of a
NIS+ object. Can follow links. Though it cannot search for an entry object,
if a link points to one, it can return an entry object.
nis_add()
Adds a NIS+ object to
the namespace.
nis_remove()
Removes a NIS+ object
in the namespace.
nis_modify()
Modifies a NIS+ object
in the namespace.
nis_tables
Searches and updates tables.
nis_list()
Searches a table in the NIS+ namespace and returns entry
objects that match the search criteria. Can follow links and search paths
from one table to another.
nis_add_entry()
Adds an entry object to a NIS+ table. Can be instructed to either fail or
overwrite if the entry object already exists. Can return a copy of the resulting
object if the operation was successful.
nis_freeresult()
Frees all memory associated with a nis_result structure.
nis_remove_entry()
Removes one or more entry objects from a NIS+ table. Can identify the object
to be removed by using search criteria or by pointing to a cached copy of
the object. If using search criteria, can remove all objects that match the
search criteria; therefore, with the proper search criteria, can remove all
entries in a table. Can return a copy of the resulting object if the operation
was successful.
nis_modify_entry()
Modifies one or more entry objects in a NIS+ table. Can identify the object
to be modified by using search criteria or by pointing to a cached copy of
the object.
nis_first_entry()
Returns a copy of the first entry object in a NIS+ table.
nis_next_entry()
Returns a copy of the “next”
entry object in a NIS+ table. Because a table can be updated and entries removed
or modified between calls to this function, the order of entries returned
might not match the actual order of entries in the table.
nis_local_names()
Gets default
names for the current process.
nis_local_directory()
Returns the name of
the workstation's NIS+ domain.
nis_local_host()
Returns the fully qualified
name of the workstation. A fully qualified name has the form host-name.domain-name.
nis_local_group()
Returns the name of
the current NIS+ group, which is specified by the environment variable NIS_GROUP.
nis_local_principal()
Returns
the name of the NIS+ principal that has a UID associated with the calling
process.
nis_getnames()
Returns
a list of possible expansions to a particular name.
nis_freenames()
Frees the memory containing the list generated by nis_getnames().
nis_groups()
Group manipulation
and authorization.
nis_ismember()
Tests whether a principal
is a member of a group.
nis_addmember()
Adds a member to a group. The member can be a principal, a group, or a domain.
nis_removemember()
Deletes a member from a group.
nis_creategroup()
Creates a group object.
nis_destroygroup()
Deletes a group object.
nis_verifygroup()
Tests whether
a group object exists.
nis_print_group_entry()
Lists the principals that are members
of a group object.
nis_server
Various services for
NIS+ applications.
nis_mkdir()
Creates
the databases to support service for a named directory on a specified host.
nis_rmdir()
Removes the directory from a host.
nis_servstate()
Sets and reads state
variables of NIS+ servers and flushes internal caches.
nis_stats()
Retrieves statistics
about a server's performance.
nis_getservlist()
Returns
a list of servers that support a particular domain.
nis_freeservlist()
Frees the list of servers returned by nis_getservlist().
nis_freetags()
Frees the memory associated with the results of nis_servstate()
and nis_stats().
nis_db
Interface between the NIS+ server and the database. Not to be used by a NIS+
client.
db_first_entry()
Returns
a copy of the first entry of the specified table.
db_next_entry()
entry succeeding the specified entry.
db_reset_next_entry()
Terminates
a first/next entry sequence.
db_list_entries()
Returns copies of entries
that meet specified attributes.
db_remove_entry()
Removes all entries
db_add_entry()
Replaces
an entry in a table identified by specified attributes with a copy of the
specified object, or adds the object to the table.
db_checkpoint()
Reorganizes the contents
of a table to make access to the table more efficient.
db_standby()
Advises the database
manager to release resources.
nis_error()
Functions that supply
descriptive strings equivalent to NIS+ status values.
nis_sperrno()
Returns a pointer to
the appropriate string constant.
nis_perror()
Displays the appropriate
string constant on standard output.
nis_lerror()
Sends the appropriate
string constant to syslog.
nis_sperror()
a statically allocated string to be used or to be copied with strdup().
nis_admin
Transaction logging functions used
by servers.
nis_ping
Used by the master server of a directory to timestamp it.
This forces replicas of the directory to be updated.
nis_checkpoint()
Forces logged data to
be stored in the table on disk.
nis_subr
Functions to help operate on NIS+ names and
objects.
nis_leaf_of()
Returns the first label
in a NIS+ name. The returned name does not have a trailing dot.
nis_name_of()
Removes all domain-related labels and
returns only the unique object portion of the name. The name passed to the
function must be either in the local domain or in one of its child domains,
or the function returns NULL.
nis_domain_of()
Returns the name of
the domain in which an object resides. The returned name ends in a dot.
nis_dir_cmp()
Compares any two NIS+
names. The comparison ignores case and states whether the names are the same,
descendants of each other, or not related.
nis_clone_object()
Creates
an exact duplicate of a NIS+ object.
nis_destroy_object()
Destroys
an object created by nis_clone_object().
nis_print_object()
Prints
the contents of a NIS+ object structure to stdout.
