When a port monitor is started, it expects an initial execution environment in which:
It has no file descriptors open.
It cannot be a process group leader.
It has an entry in /var/adm/utmpx of type LOGIN_PROCESS.
An environment variable, ISTATE, is set to enabled or disabled
to indicate the port monitor's correct initial state .
An environment variable, PMTAG, is set to the port monitor's assigned tag.
The directory that contains the port monitor's administrative files is its current directory.
The port monitor is able to create private files in the directory /var/saf/tag, where tag is the port monitor's tag.
