ONC+ Developer's Guide
Per-System Configuration Scripts
Per-system configuration scripts are administered by using the sacadm command.
sacadm -G  [ -z script ]
The -G option is used to print or replace the per-system configuration script. The -G option by itself prints the per-system configuration script. The -G option in combination with a -z option replaces /etc/saf/_sysconfig with the contents of the file script. Other combinations of options with a -G option are invalid.
The _sysconfig file in the following example sets the time zone variable, TZ.
assign TZ=EST5EDT # set TZ
runwait echo SAC is starting > /dev/console
