The assign keyword is used to define environment variables.
assign variable=value
variable is the name of the environment variable and value is the value to be assigned to it. The value assigned must be a string constant. No form of parameter substitution is available. value can be quoted. The quoting rules are those that the shell uses for defining environment variables. assign fails if space cannot be allocated for the new variable or if any part of the specification is invalid.
