ONC+ Developer's Guide
Time-out Changes
After sending a request to the server, a client program waits for a default period (25 seconds) to receive a reply. You can change this timeout by using the clnt_control() routine. See Standard Interfaces for additional uses of the clnt_control() routine. See also the rpc(3NSL) man page. When considering time-out periods, be sure to allow the minimum amount of time required for “round-trip” communications over the network. The following code example illustrates the use of clnt_control().
Example 3–24 clnt_control Routine
struct timeval tv;
CLIENT *clnt;
clnt = clnt_create( "somehost", SOMEPROG,
									SOMEVERS, "visible" );
if (clnt == (CLIENT *)NULL)
	exit(1);
tv.tv_sec = 60;	/* change time-out to
							 * 60 seconds
tv.tv_usec = 0;
clnt_control(clnt, CLSET_TIMEOUT, &tv);
