Call semantics define what the client can assume about the execution of the remote procedure; in particular, how many times the procedure was executed. These semantics are important in dealing with error conditions. The three alternatives are exactly once, at most once, and at least once. ONC+ provides at least once semantics. Procedures called remotely are idempotent: they should return the same result each time they are called, even through several iterations.
