The following data structure information is for reference only. The implementation might change.
The first structure is the client RPC handle, defined in <rpc/clnt.h>. Low-level implementations must provide and initialize one handle per connection, as shown in the following code example.
typedef struct { AUTH *cl_auth; /* authenticator */ struct clnt_ops { enum clnt_stat (*cl_call)(); /* call remote procedure */ void (*cl_abort)(); /* abort a call */ void (*cl_geterr)(); /* get specific error code */ bool_t (*cl_freeres)(); /* frees results */ void (*cl_destroy)(); /* destroy this structure */ bool_t (*cl_control)(); /* the ioctl() of rpc */ } *cl_ops; caddrt_t cl_private; /* private stuff */ char *cl_netid; /* network token */ char *cl_tp; /* device name */ } CLIENT;
The first field of the client-side handle is an authentication structure, defined in <rpc/auth.h>. By default, this field is set to AUTH_NONE. A client program must initialize cl_auth appropriately, as shown in the following code example.
typedef struct { struct opaque_auth ah_cred; struct opaque_auth ah_verf; union des_block ah_key; struct auth_ops { void (*ah_nextverf)(); int (*ah_marshal)(); /* nextverf & serialize */ int (*ah_validate)(); /* validate varifier */ int (*ah_refresh)(); /* refresh credentials */ void (*ah_destroy)(); /* destroy this structure */ } *ah_ops; caddr_t ah_private; } AUTH;
In the AUTH structure, ah_cred contains the caller's credentials, and ah_verf contains the data to verify the credentials. See Authentication for details.
The following code example shows the server transport handle.
typedef struct { int xp_fd; #define xp_sock xp_fd u_short xp_port; /* associated port number. Obsoleted */ struct xp_ops { bool_t (*xp_recv)(); /* receive incoming requests */ enum xprt_stat (*xp_stat)(); /* get transport status */ bool_t (*xp_getargs)(); /* get arguments */ bool_t (*xp_reply)(); /* send reply */ bool_t (*xp_freeargs)(); /* free mem alloc for args */ void *xp_destroy)(); /* destroy this struct */ } *xp_ops; int xp_addrlen; /* length of remote addr. Obsolete */ char *xp_tp; /* transport provider device name */ char *xp_netid; /* network token */ struct netbuf xp_ltaddr; /* local transport address */ struct netbuf xp_rtaddr; /* remote transport address */ char xp_raddr[16]; /* remote address. Now obsoleted */ struct opaque_auth xp_verf; /* raw response verifier */ caddr_t xp_p1; /* private: for use by svc ops */ caddr_t xp_p2; /* private: for use by svc ops */ caddr_t xp_p3; /* private: for use by svc lib */ } SVCXPRT;
The following table shows the fields for the server transport handle.
xp_fd |
The file descriptor associated with the handle. Two or more server handles can share the same file descriptor. |
xp_netid |
The network identifier (for example, udp) of the transport on which the handle is created and xp_tp is the device name associated with that transport. |
xp_ltaddr |
The server's own bind address. |
xp_rtaddr |
The address of the remote caller (and so can change from call to call). |
xp_netid xp_tp xp_ltaddr |
Initialized by svc_tli_create() and other expert-level routines. |
The rest of the fields are initialized by the bottom-level server routines svc_dg_create() and svc_vc_create().
For connection-oriented endpoints, the following fields are not valid until a connection has been requested and accepted for the server:
