XDR routines normally serialize and deserialize data. XDR routines often
automatically allocate memory and free automatically allocated memory. The
convention is to use a NULL
pointer to an array or structure
to indicate that an XDR function must allocate memory when deserializing.
The next example, xdr_chararr1(), processes a fixed array
of bytes with length SIZE and cannot allocate memory if
needed:
xdr_chararr1(xdrsp, chararr) XDR *xdrsp; char chararr[]; { char *p; int len; p = chararr; len = SIZE; return (xdr_bytes(xdrsp, &p, &len, SIZE)); }
If space has already been allocated in chararr, it can be called from a server as follows.
char chararr[SIZE]; svc_getargs(transp, xdr_chararr1, chararr);
Any structure through which data is passed to XDR or RPC routines must be allocated so that its base address is at an architecture-dependent boundary. An XDR routine that does the allocation must be written so that it can:
Allocate memory when a caller requests
Return the pointer to any memory it allocates
In the following example, the second argument is a NULL pointer, meaning that memory should be allocated to hold the data being deserialized.
xdr_chararr2(xdrsp, chararrp) XDR *xdrsp; char **chararrp; { int len; len = SIZE; return (xdr_bytes(xdrsp, charrarrp, &len, SIZE)); }
The corresponding RPC call is:
char *arrptr; arrptr = NULL; svc_getargs(transp, xdr_chararr2, &arrptr); /* * Use the result here */ svc_freeargs(transp, xdr_chararr2, &arrptr);
After use, free the character array through svc_freeargs(). svc_freeargs() does nothing if passed a NULL pointer as its second argument.
To summarize:
