ONC+ Developer's Guide
RPCL Constants
You can use XDR symbolic constants wherever an integer constant is used. A typical use might be in array size specifications:
   const-definition:
   const const-ident = integer
The following example defines a constant, DOZEN, as equal to 12.
const DOZEN = 12; --> #define DOZEN 12
