ONC+ Developer's Guide
AUTH_KERB Authentication
To avoid compiling Kerberos code into the operating system kernel, the kernel used in the S implementation of AUTH_KERB uses a proxy RPC daemon called kerbd. The daemon exports three procedures.
The best way to describe how Kerberos works is to use an example based on a service currently implementing Kerberos: the network file system (NFS). The NFS service on server s is assumed to have the well-known principal name nfs.s. A privileged user on client c is assumed to have the primary name root and an instance c. Note that, unlike AUTH_DES, when the user's ticket-granting ticket has expired, kinit() must be reinvoked. NFS service for Kerberos mounts fail until a new ticket-granting ticket is obtained.
NFS Mount Example
This section follows an NFS mount request from start to finish using AUTH_KERB. Because mount requests are executed as root, the user's identity is root.c.
Client c makes a MOUNTPROC_MOUNT request to the server s to obtain the file handle for the directory to be mounted. The client mount program makes an NFS mount system call, handing the client kernel the file handle, mount flavor, time synchronization address, and the server's well-known name, nfs.s. Next the client kernel contacts the server at the time synchronization host to obtain the client-server time bias.
The client kernel makes the following RPC calls.
  1. KSETKCRED to the local kerbd to obtain the ticket and session key,
  2. NFSPROC_GETATTR to the server's NFS service, using the full name credential and verifier. The server receives the calls and makes the KGETKCRED call to its local kerbd to check the client's ticket.
The server's kerbd and the Kerberos library decrypt the ticket and return, among other data, the principal name and DES session key. The server checks that the ticket is still valid, uses the session key to decrypt the DES-encrypted portions of the credential and verifier, and checks that the verifier is valid.
The possible Kerberos authentication errors returned at this time are:
If no errors are received, the server caches the client's identity and allocates a nickname, which is a small integer, to be returned in the NFS reply. The server then checks if the client is in the same realm as the server. If so, the server calls KGETUCRED to its local kerbd to translate the principal's primary name into UNIX credentials. If the previous name is not translatable, the user is marked anonymous. The server checks these credentials against the file system's export information. Consider these three cases:
  1. If the KGETUCRED call fails and anonymous requests are allowed, the UNIX credentials of the anonymous user are assigned.
  2. If the KGETUCRED call fails and anonymous requests are not allowed, the NFS call fails with the AUTH_TOOWEAK.
  3. If the KGETUCRED call succeeds, the credentials are assigned, and normal protection checking follows, including checking for root permission.
Next, the server sends an NFS reply, including the nickname and server's verifier. The client receives the reply, decrypts and validates the verifier, and stores the nickname for future calls. The client makes a second NFS call to the server, and the calls to the server described previously are repeated. The client kernel makes an NFSPROC_STATVFS call to the server's NFS service, using the nickname credential and verifier described previously. The server receives the call and validates the nickname. If it is out of range, the error AUTH_BADCRED is returned. The server uses the session key just obtained to decrypt the DES-encrypted portions of the verifier and validates the verifier.
If no errors are received, the server uses the nickname to retrieve the caller's UNIX credentials. Then it checks these credentials against the file system's export information, and sends an NFS reply that includes the nickname and the server's verifier. The client receives the reply, decrypts and validates the verifier, and stores the nickname for future calls. Last, the client's NFS mount system call returns, and the request is finished.
KERB Authentication Protocol
The following example of AUTH_KERB has many similarities to the one for AUTH_DES, shown in the following code example. Note the differences.
Example B–3 AUTH_KERB Authentication Protocol
#define AUTH_KERB 4
 * There are two kinds of credentials: one in which the client
 * sends the (previously encrypted)
Kerberos ticket, and one in
 * which it uses its “nickname” (just an unsigned integer)
 * given to it by the server. The client must use its full name
 * in its first transaction with the server, in which the server
 * returns to the client its nickname. The client may use
 * its nickname in all further transactions with the server
 * (until the ticket expires). There is no requirement to use
 * the nickname, but it is wise to use it for performance reasons.
enum authkerb_namekind {
 	AKN_FULLNAME = 0,
 	AKN_NICKNAME = 1
 * A fullname contains the encrypted service ticket and the
 * window. 	The window is actually a lifetime
 * for the credential. If the time indicated in the verifier
 * timestamp plus the window has passed, then the server should
 * expire the request and not grant it. To insure that requests
 * are not replayed, the server should insist that timestamps be
 * greater than the previous one seen, unless it is the first
 * transaction. In the first transaction, the server checks
 * instead that the window verifier is one less than the window.
struct authkerb_fullname {
 	KTEXT_ST ticket;              /* Kerberos service ticket */
 	unsigned long window;        /* encrypted window */
 * A credential is either a fullname or a nickname
union authkerb_credswitch(authkerb_namekind akc_namekind){
 	case AKN_FULLNAME:
 		authkerb_fullname akc_fullname;
 	case AKN_NICKNAME:
 		unsigned long akc_nickname;
 * A timestamp encodes the time since midnight, January 1, 1970.
struct timestamp {
 	unsigned long seconds;      /* seconds */
 	unsigned long useconds;     /* and microseconds */
 * Verifier: client variety
struct authkerb_verf_clnt {
 	timestamp akv_timestamp;   /* encrypted timestamp */
 	unsigned long akv_winverf;  /* encrypted window verifier */
 * Verifier: server variety
 * The server returns (encrypted) the same timestamp the client
 * gave it minus one second. It also tells the client its
 * nickname to be used
in future transactions (unencrypted).
struct authkerb_verf_svr {
 	timestamp akv_timeverf;    /* encrypted verifier */
 	unsigned long akv_nickname; /* new nickname for clnt */
