ONC+ Developer's Guide
RPCSEC_GSS API
The RPCSEC_GSS security flavor enables ONC RPC applications to maximize the features of GSS-API. RPCSEC_GSS sits “on top” of the GSS-API layer as shown in the following figure.
Figure 5–1 GSS-API and RPCSEC_GSS Security Layers
RPSEC_GSS is between the application and GSS-API.
Using the programming interface for RPCSEC_GSS, ONC RPC applications can specify the following information:
Applications can obtain lists of valid QOPs and mechanisms through functions provided by RPCSEC_GSS. See Miscellaneous Functions. Developers should avoid hard-coding mechanisms and QOPs into their applications, so that the applications do not need to be modified to use new or different mechanisms and QOPs.
Note –
Historically, “security flavor” and “authentication flavor” have had the same meaning. With the introduction of RPCSEC_GSS, “flavor” now has a somewhat different sense. A flavor can now include a service integrity or privacy along with authentication, although currently RPCSEC_GSS is the only flavor that falls into this category.
Using RPCSEC_GSS, ONC RPC applications establish a security context with a peer, exchange data, and destroy the context, just as they do with other flavors. After a context is established, the application can change the QOP and service for each data unit sent.
For more information on RPCSEC_GSS, including RPCSEC_GSS data types, see the rpcsec_gss(3N) man page.
