Federated Naming Service Programming Guide
Chapter 3 XFN Programming Examples
This chapter presents self-contained executable programs for the following programs:
Namespace Browser Example
Figure 3–1 illustrates the XFN APIs that are used by the browser application.
Figure 3–1 Diagram of fnbrowse Program
Diagram shows how fnsbrowse uses APIs.
The first example is a browser that lists all names that it finds in the namespace. When the program is invoked, the browser is set at the initial context or the composite name given on the command line.
See Commands and Sample Output.
Example 3–1 fnbrowse Source
 * fnbrowse.c -- FNS namespace browser.
 * To keep this example program relatively short,
 * limited error checking is done.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <xfn/xfn.h>
#define LINELEN 128    /* maximum length of input line */
typedef enum {CMD_DOWN, CMD_UP, CMD_LIST, CMD_SHOW, CMD_QUIT} command;
static FN_status_t *status;
static unsigned 	int auth = 0; /* non-authoritative */
/* Lookup a context named relative to the initial context. */
FN_ctx_t *lookup(const FN_composite_name_t *name);
/* Set the browser's focus to the given context. */
void browse(FN_ctx_t *ctx);
/* Set the browser's focus to a subcontext of the given context. */
void cmd_down(FN_ctx_t *ctx, const FN_composite_name_t *child);
/* Print the names bound within a context. */
void cmd_list(FN_ctx_t *ctx);
 * Print a description of the reference bound to "child" in the
 * given context or, if "child" is the empty string, the reference
 * of the context itself.
void cmd_show(FN_ctx_t *ctx, const FN_composite_name_t *child);
 * Read and parse the next command typed by the user.  If the
 * command has an argument, set *argp to point to the argument.
command read_command(FN_string_t **argp);
/* Print an error message, and the description associated
 * with "status".
void error(const char *msg);
int
main(int argc, char *argv[])
	    unsigned char	*target;
	    switch (argc) {
    case 1:
        target = (unsigned char *)"";
        break;
    case 2:
        target = (unsigned char *)argv[1];
        break;
    default:
        fprintf(stderr, "Usage: %s [<composite_name>]\n",
             argv[0]);
        return (1);
    status = fn_status_create();
    browse(lookup(fn_composite_name_from_str(target)));
    return (0);
FN_ctx_t *
    FN_ctx_t	*ctx;
    FN_ref_t	*ref;
    ctx = fn_ctx_handle_from_initial(auth, status);
    if (ctx == NULL) {
       error("Could not construct initial context");
       exit(1);
    if (fn_composite_name_is_empty(name)) {
        return (ctx);
    ref = fn_ctx_lookup(ctx, name, status);
    fn_ctx_handle_destroy(ctx);
    if (ref == NULL) {
       error("Lookup failed");
       exit(1);
    ctx = fn_ctx_handle_from_ref(ref, auth, status);
    fn_ref_destroy(ref);
    if (ctx == NULL) {
       error("Could not construct context handle");
       exit(1);
    return (ctx);
void
  FN_string_t		*arg;
  FN_composite_name_t	*child;
  while (1) {
     switch (read_command(&arg)) {
     case CMD_DOWN:
        child = fn_composite_name_from_string(arg);
        fn_string_destroy(arg);
			  cmd_down(ctx, child);
        fn_composite_name_destroy(child);
        break;
     case CMD_UP:
        return;
     case CMD_LIST:
        cmd_list(ctx);
        break;
     case CMD_SHOW:
        cmd_show(ctx, child);
        break;
     case CMD_QUIT:
        exit(0);
void
  FN_ref_t	*ref;
  FN_ctx_t	*subctx;
  ref = fn_ctx_lookup(ctx, child, status);
  if (ref == NULL) {
      return;
  subctx = fn_ctx_handle_from_ref(ref, auth, status);
	  if (subctx == NULL) {
      return;
  browse(subctx);
  fn_ctx_handle_destroy(subctx);
void
  FN_string_t		*empty_string = fn_string_create();
  FN_composite_name_t	*empty_name;
  FN_namelist_t		*children;
  FN_string_t		*child;
  unsigned intstatcode;
  int  has_children = 0;
  empty_name = fn_composite_name_from_string(empty_string);
  fn_string_destroy(empty_string);
  children = fn_ctx_list_names(ctx, empty_name, status);
  fn_composite_name_destroy(empty_name);
  if (children == NULL) {
      error("Could not list names");
      return;
  while ((child = fn_namelist_next(children, status))
    != NULL) {
    has_children = 1;
    printf("%s  ", fn_string_str(child, &statcode));
    fn_string_destroy(child);
  if (has_children) {
      printf("\n");
  fn_namelist_destroy(children);
void
    FN_string_t	*desc;
    FN_ref_t	*ref;
    unsigned int	statcode;
    if (ref == NULL) {
        return;
    desc = fn_ref_description(ref, 2, NULL);
    if (desc != NULL) {
        printf("%s", fn_string_str(desc, &statcode));
        fn_string_destroy(desc);
    } else {
        printf("[No description]\n");
command
     char	buf[LINELEN + 1];
     char  *cmd;
     char  *child;
     while (printf("\n> "), fflush(stdout), gets(buf) != NULL) {
        cmd = strtok(buf, " \t");
        if (cmd == NULL) {
            continue;
        if (strcmp(cmd, "down") == 0) {
           child = strtok(NULL, " \t");
           if (child != NULL) {
              *argp =
                  fn_string_from_str((unsigned char *)child);
              return (CMD_DOWN);
        if (strcmp(cmd, "up") == 0) {
           return (CMD_UP);
        if (strcmp(cmd, "list") == 0) {
           return (CMD_LIST);
        if (strcmp(cmd, "show") == 0) {
           *argp = (child != NULL)
               ? fn_string_from_str((unsigned char *)child)
               : fn_string_create();
           return (CMD_SHOW);
        if (strcmp(cmd, "quit") == 0) {
           return (CMD_QUIT);
       fprintf(stderr, "Valid commands are:  "
           "down <child>, up, list, show [<child>], quit\n");
    return (CMD_QUIT);	/* EOF */
void
    FN_string_t	*reason;
    fprintf(stderr, "%s", msg);
    reason = fn_status_description(status, 0, NULL);
    if (reason != NULL) {
        fprintf(stderr, ": %s",
            (const char *)fn_string_str(reason, &statcode));
        fn_string_destroy(reason);
    fprintf(stderr, "\n");
Compiling and Executing Browser Example
To compile Example 3–1, type:
% cc -o fnbrowse fnbrowse.c -lxfn
To browse the namespace starting from the initial context, the program is invoked as:
% fnbrowse
Or to browse a composite name and its descendents, type:
% fnbrowse composite_name
Commands
The commands supported by the fnbrowse program are summarized in Table 3–1 .
Table 3–1 Namespace Browser Commands
Command
Usage
down child
Sets the browser at the subcontext of the child
up
Sets the browser at one level higher than the current context
list
Lists the names bound within the current context
show
Prints the reference of the current context
show child
Prints the reference of the current context's child
quit
Exits the browser
Sample Output
Sample output for navigating the entire namespace is displayed here.
Note the following:
% fnbrowse
> list
_myorgunit  ...  _myself  thishost  myself  _orgunit  _host
_thisens  myens  thisens  org  orgunit  thisuser  _thishost
myorgunit  _user  thisorgunit  host  _thisorgunit  _myens  user
Navigating the namespace is accomplished with the up and down commands. In the following output, the down command brings the focus of the browser to the enterprise root of the namespace, thisens (can also be myens). The show command displays information about the reference and address type for thisens.
> down thisens
> show
Reference type: onc_fn_enterprise
Address type: on_fn_nisplus
  length: 20
  context type: enterprise root
  representation: normal
  version: 0
  internal name: eng.wiz.com
> up
> down thisorgunit
Continuing with the example, this list command shows the contexts for thisorgunit.
> list
service  _fs  _host  _service  _site  site  _user  host  fs  user
> down usr
Lookup failed: Name Not Found: 'usr'
> down service
> list
printer
> down printer
The list command shows the printer names that are bound in the printer context. The show command displays the reference for the child, colorful.
> list
celeste  _default  color  colorful  quartz  nuttree  puffin
> show colorful
printer
Reference type: onc_printers
Address type: onc_printers_bsdaddr
  length: 12
  data: 0x00 0x00 0x00 0x08 0x62 0x6c 0x61 0x63 0x6b 0x63
....blackc 0x61 0x74 at
> down colorful
Could not construct context handle: No Supported Address
> quit
Printer Programming Example
Printer client and server software can take advantage of FNS to advertise and to browse the printers available with respect to organizations, sites, users, and hosts. The APIs used by the server and the client are XFN APIs, thereby ensuring that the application is portable across the different naming services used for storing printer bindings.
The programming example in this section shows how printer clients and servers obtain and store printer bindings. Users can then make use of the FNS commands, fnlist and fnlookup, to browse the printer context.
For example, use fnlist to look at the user printer context for jsmith:
% fnlist user/jsmith/service/printer
celeste
lp
_default
myprinter
Similarly, you can look at the organization's printers:
% fnlist org/wiz.com/service/printer
sales_printer
mktg_printer
eng_printer
Alternatively, you can type:
% fnlist thisorgunit/service/printer
You can look at the printers at a specific site, for example, the printers in the MTV site:
% fnlist thisorgunit/site/MTV/service/printer
b1_printer
b2_printer
Client
The scenario for Example 3–2 is a user who would like to print to a printer named colorful in his organization's context, thisorgunit/service/printer/colorful. The example printer client illustrates how the bindings for a specific printer are obtained.
The variable printer_binding contains the reference (the binding information) of the named printer. Using the binding information, the printer client can connect to the server and send the printer request. Note that the fn_ctx_lookup() function can be replaced by fn_ctx_list_name() or fn_ctx_list_bindings() to list all the names and their bindings.
Example 3–2 Print Client source
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
 * Routine to obtain the address of a specific printe.
 * This routine takes the printer name and the address type
 * as the input arguments and returns the address
 * of the requested printer.
char *
get_address_of_printer(const char *printer_name,
	    const char *address_type)
   FN_composite_name_t *printer_name_comp;
   FN_status_t *status = fn_status_create();
   FN_ctx_t *initial_context;
   FN_ref_t *printer_ref;
   const FN_identifier_t *addr_id;
   const FN_ref_addr_t *address;
   char *addr_data; /* Return value */
   void *ip;
   size_t address_type_len, addr_len;
   /* Convert the printer name to a composite name */
   printer_name_comp = fn_composite_name_from_string(
      (const unsigned char *)printer_name);
   /* Get the initial context */
   initial_context = fn_ctx_handle_from_initial(0, status);
   /* Check status for any error messages */
   if (!fn_status_is_success(status)){
    fprintf(stderr,
         "Unable to obtain the initial context\n");
    return (0);
  /* Perform a lookup for the printer name */
  printer_ref = fn_ctx_lookup(initial_context,
     printer_name_comp, status);
    fprintf(stderr, "Lookup failed on: %s\n",
        printer_name);
    return (0);
  fn_ctx_handle_destroy(initial_context);
  fn_composite_name_destroy(printer_name_comp);
  address_type_len = strlen(address_type);
  /* Obtain the requested address from the address type */
  for (address = fn_ref_first(printer_ref, &ip);
     address != NULL;
     address = fn_ref_next(printer_ref, &ip)) {
         addr_id = fn_ref_addr_type(address);
         if (addr_id->length == address_type_len &&
            strncmp(address_type,
                (char *)addr_id->contents,
                address_type_len) == 0)
                break;
  if (address == NULL)
      return (0);
  addr_len = fn_ref_addr_length(address);
  addr_data = (char *)(malloc(addr_len + 1));
  strncpy(addr_data,(char*)(fn_ref_addr_data(address)),
          addr_len);
  addr_data[addr_len] = '\0';
  fn_ref_destroy(printer_ref);
  return (addr_data);
Calling the Printer Client Function
The following code could be used to call the get_address_of_printer() routine shown above.
char* printer_server;
printer_server = get_address_of_printer
    "thisorgunit/service/printer/colorful",
    "onc_bsdaddr");
Server
Using the XFN APIs, print servers can advertise their services. Example 3–3 illustrates a host, labpc, that would like to advertise the binding for the color printer colorful. The FNS name for this printer is thisorgunit/service/printer/colorful.
The main tasks are to obtain the composite name for the printer name, to generate the binding (reference) for the printer, and to bind the name and references to the FNS namespace.
Example 3–3 Print Server Source
#include <stdio.h>
#include <string.h>
 * Routine to export the printer binding to the FNS name space.
 * This routine takes the printer name along with its
 *  reference type, address type, and address. Returns the status.
int
export_printer_to_fns(const char *printer_name,
		      const char *reference_type,
		      const char *address_type,
		      const char *address_data)
  int return_status;
  FN_identifier_t ref_id, addr_id;
  /* Obtain the initial context */
  if ((return_status = fn_status_code(status)) != FN_SUCCESS) {
      fprintf(stderr, "Unable to obtain the initial context\n");
      return (return_status);
  /* Construct the composite name for the printer name */
      (unsigned char *)printer_name);
  /* Construct the printer address */
  addr_id.format = FN_ID_STRING;
  addr_id.length = strlen(address_type);
  addr_id.contents = (void *) address_type;
  address = fn_ref_addr_create(&addr_id,
      strlen(address_data), (const void *) address_data);
  /* Construct the printer reference */
  ref_id.format = FN_ID_STRING;
	  ref_id.length = strlen(reference_type);
	  ref_id.contents = (void *) reference_type;
  	printer_ref = fn_ref_create(&ref_id);
	  /* Add the printer address to the printer reference */
	  fn_ref_append_addr(printer_ref, address);
  	/* Bind the reference to the context */
  	fn_ctx_bind(initial_context, printer_name_comp, printer_ref, 0,
          status);
	  /* Check the error status and return */
  return_status = fn_status_code(status);
  fn_ref_addr_destroy(address);
  fn_status_destroy(status);
Calling the Printer Server Function
The following code could be used to call the export_printer_to_fns() routine shown above.
	    "onc_printers",
	    "onc_bsdaddr",
	    "labpc");
