This section describes the operations in the base attribute interface. The interfaces to the objects used in operations in this interface are described in Parameters Used in the Interface.
In the XFN attribute model, a set of zero or more attributes can be associated with a named object. Each attribute in the set has a unique attribute identifier, an attribute syntax, and a set of zero or more distinct attribute values. Each attribute value has an opaque data type. The attribute identifier serves as a name for the attribute. The attribute syntax indicates how the attribute values are encoded.
The operations in the base attribute interface can be used to examine and modify the settings of attributes associated with existing named objects. These objects can be contexts or other types of objects. The attribute operations do not create names or remove names in contexts.
The range of support for attribute operations can vary widely. Some naming systems might not support any attribute operations. Other naming systems might support only read operations or operations on attributes whose identifiers are in some fixed set. A naming system might limit attributes to have single values or might require at least one value. Some naming systems might associate attributes only with context objects, while others might allow associating attributes with non-context objects.
Typically, attributes of an object are manipulated through operations that operate on a single attribute, such as reading or updating a single attribute. Moreover, the client is typically expected to be able to read all attribute values of a single attribute in one call. However, sometimes there is a requirement to manipulate several attributes of a single object or to obtain individual attribute values of a single attribute from the name service. To address these requirements, two kinds of attribute operations are defined:
An XFN attribute operation might not be equivalently expressed as an independent fn_ctx_lookup() operation followed by an attribute operation in which the caller supplies the resulting reference and an empty name.
This is because some attribute models associate attributes with a named object in the context in which the object is named. In others, an object's attributes are stored in the object itself. XFN accommodates both these models.
Invoking an attribute operation using the target context and the terminal atomic name accesses either the attributes that are associated with the terminal name or the object named by the terminal name—this is dependent upon the underlying attribute model. This document uses the term “attributes associated with a named object” to refer to all of these cases.
XFN does not provide any guarantee about the validity of the relationship between the attributes and the reference associated with a given name. Some naming systems might store the reference bound to a name in one or more attributes associated with a name. Attribute operations might affect the information used to construct a reference.
To avoid undefined results, programmers must use the operations in the context interface and not the attribute operations when manipulating references. Applications should avoid using specific knowledge about how an XFN context implementation over a particular naming system constructs references.
In each attribute operation, the caller supplies an FN_status_t parameter. The called function sets this status object as described in Status Objects and Status Codes. All status objects are handled in this manner for each operation in the base attribute interface; this will not be restated in the individual operation descriptions.
fn_attr_get fn_attr_modify fn_attr_get_values fn_valuelist_next fn_valuelist_destroy |
Each of these operations takes as arguments a context and composite name relative to this context and manipulates the attributes associated with the named object. Each operation sets a status object to describe the status of the operation.
This operation returns the identifier, syntax, and values of a specified attribute, attribute_id, for the object named name relative to the context ctx. If name is empty, the attribute associated with ctx is returned.
FN_attribute_t *fn_attr_get(
FN_ctx_t *ctx,
const FN_composite_name_t *name,
const FN_identifier_t *attribute_id,
unsigned int follow_link,
FN_status_t *status);
fn_attr_get_values() and its related functions are for getting individual values of an attribute and should be used if the combined size of all the values is expected to be too large to be returned in a single invocation of fn_attr_get().
This operation modifies according to mod_op the attribute attr associated with the object named name, relative to ctx. If name is empty, the attribute associated with ctx is modified.
int fn_attr_modify(
FN_ctx_t *ctx,
unsigned int mod_op,
const FN_attribute_t *attr,
Operation Code |
Meaning |
Add an attribute with given attribute identifier and set of values. If an attribute with this identifier already exists, replace the set of values with those in the given set. The set of values can be empty if the target naming system permits. |
Add an attribute with the given attribute identifier and set of values. The operation fails if an attribute with this identifier already exists. The set of values can be empty if the target naming system permits. |
Add the given values to those of the given attribute (resulting in the attribute having the union of its prior value set with the given set). Create the attribute if it does not already exist. The set of values can be empty if the target naming system permits. |
Remove the attribute with the given attribute identifier and all its values. The operation succeeds even if the attribute does not exist. The values of the attribute supplied with this operation are ignored. |
Remove the given values from those of the given attribute (resulting in the attribute having the set difference of its prior value set and the given set). This succeeds even if some of the given values are not in the set of values that the attribute has. In naming systems that require an attribute to have at least one value, removing the last value removes the attribute as well. |
This set of operations allows the caller to obtain attribute values associated individually with a single attribute.
This set of operations is used to obtain the set of values of a single attribute, identified by attribute_id, associated with name, relative to ctx. If name is empty, the attribute associated with ctx is obtained.
This interface should be used instead of fn_attr_get() if the combined size of all the values is expected to be too large to be returned by fn_attr_get().
The operation fn_attr_get_values() initiates the enumeration process. It returns a handle to an FN_valuelist_t object that can be used for subsequent fn_valuelist_next() calls to enumerate the values requested.
The operation fn_valuelist_next() returns the next attribute value in the enumeration and updates vl to indicate the state of the enumeration.
The operation fn_valuelist_destroy() frees the resources associated with the enumeration. This operation can be invoked at any time to terminate the enumeration.
fn_attr_get_ids fn_attr_multiget fn_multigetlist_next fn_multigetlist_destroy fn_attr_multi_modify |
These operations allow the caller to specify an operation that handles on multiple attributes using one or more calls.
The failure semantics can vary widely across naming systems. In some systems the single function call can contain multiple individual naming system operations, with no guarantees of atomicity.
This operation gets a list of all the attribute identifiers that are associated with the object named name relative to the context ctx. If name is empty, the attribute identifiers associated with ctx are returned.
FN_attrset_t *fn_attr_get_ids(
FN_ctx_t *ctx,
Get one or more attributes associated with the object named name relative to the context ctx. If name is empty, the attributes associated with ctx are returned.
FN_multigetlist_t *fn_attr_multiget(
FN_ctx_t *ctx,
const FN_attrset_t *attr_ids,
FN_attribute_t *fn_multigetlist_next(
FN_multigetlist_t *ml,
void fn_multigetlist_destroy(
FN_multigetlist_t *ml);
The attributes returned are those specified in attr_ids. If the value of attr_ids is 0, all attributes associated with the named object are returned. Any attribute values in attr_ids provided by the caller are ignored; only the identifiers are relevant for this operation. Each attribute (identifier, syntax, and values) is returned one at a time using an enumeration scheme similar to that for listing a context. fn_attr_multi_get() initiates the enumeration process. It returns a handle to an FN_multigetlist_t object that can be used for subsequent fn_multigetlist_next() calls to enumerate the attributes requested.
The operation fn_multigetlist_next() returns the next attribute (identifier, syntax, and values) in the enumeration and updates ml to indicate the state of the enumeration. Successive calls to fn_multigetlist_next() using ml return successive attributes in the enumeration and further update the state of the enumeration.
The operation fn_multigetlist_destroy() frees the resources used during the enumeration. This operation can be invoked at any time to terminate the enumeration.
Implementations are not required to return all attributes requested by attr_ids. Some might choose to return only the attributes found successfully; such implementations might not necessarily return identifiers for attributes that could not be read.
Modify the attributes associated with the object named name, relative to ctx.
int fn_attr_multi_modify(
FN_ctx_t *ctx,
const FN_attrmodlist_t *mods,
FN_attrmodlist_t **unexecuted_mods,
In the mods parameter, the caller specifies a sequence of modifications that are to be performed in order on the attributes. Each modification in the sequence specifies a modification operation code (shown in Table 2–1) and an attribute on which to operate.
If all the modifications were performed successfully, unexecuted_mods is a NULL pointer. If an error is encountered while performing the list of modifications, status indicates the type of error and unexecuted_mods is set to point to a list of unexecuted modifications. The contents of unexecuted_mods do not share any state with mods; items in unexecuted_mods are copies of items in mods and appear in the same order in which they were originally supplied in mods. The first operation in unexecuted_mods is the first one that failed, and the code in status applies to this modification operation in particular. If status indicates a failure and a NULL pointer is returned in unexecuted_mods, that means no modifications were executed.
