Federated Naming Service Programming Guide
Substitute Tokens in Search Filter Expressions
Precedence
The following precedence relations hold in the absence of parentheses, in the order of lowest to highest:
These Boolean and relational operators are left associative.
Relational Operators
Table 2–7 contains descriptions of the relational operators. Comparisons and ordering are specific to the syntax or rules of the supplied attribute.
Locale (code set, language or territory) mismatches that occur during string comparisons and ordering operations are resolved in an implementation-dependent way. Relational operations that have ordering semantics may be used for strings of locales in which ordering is meaningful, but is not of general use in internationalized environments.
An attribute that occurs in the absence of any relational operator tests for the presence of the attribute.
Table 2–7 Relational Operators in Search Filter Expressions
Operator
Meaning
The sub-expression is TRUE if at least one value of the specified attribute is equal to the supplied value.
The sub-expression is TRUE if no values of the specified attribute equal the supplied value.
The sub-expression is TRUE if at least one value of the attribute is greater than or equal to the supplied value.
The sub-expression is TRUE if at least one value of the attribute is greater then the supplied value.
The sub-expression is TRUE if at least one value of the attribute is less than or equal to the supplied value.
The sub-expression is TRUE if at least one value of the attribute is less than the supplied value.
The sub-expression is TRUE if at least one value of the specified attribute matches the supplied value according to some context-specific approximate matching criterion. This criterion must subsume strict equality.
Wildcarded Strings
A wildcarded string consists of a sequence of alternating wildcard specifiers and strings. The sequence can start with either a wildcard specifier or a string, and end with either a wildcard specifier or a string.
The wildcard specifier is denoted by the asterisk character (*) and means 0 or more occurrences of any character.
Wildcarded strings can be used to specify substring matches. Table 2–8 contains examples of wildcarded strings and their meaning.
Table 2–8 Examples of Wildcarded Strings
Wildcarded String
Meaning
Any string
`tom'
The string tom
`harv'*
Any string starting with harv
*'ing'
Any string ending with ing
`a'*'b'
Any string starting with a and ending with b
`a*b'
The string a*b
`jo'*'ph'*'ne'*'er'
Any string starting with jo, and containing the substring ph, and which contains the substring ne in the portion of the string following ph, and which ends with er
%s*
Any string starting with the supplied string
`bix'*%s
Any string starting with bix and ending with the supplied string
Extended Operations
In addition to the relational operators, extended operators can be specified. All extended operators return either TRUE or FALSE. A filter expression can contain both relational and extended operations.
Extended operators are specified using an identifier (FN_identifier_t) or a string. If the operator is specified using a string, the string is used to construct an identifier of format FN_ID_STRING. Identifiers of extended operators and signatures of the corresponding extended operations, as well as their suggested semantics, are registered with X/Open.
The extended operations shown in Table 2–9 are currently defined:
Table 2–9 Extended Operations
`name'(<Wildcarded String>)
The identifier for this operation is name(FN_ID_STRING). The argument to this operation is a wildcarded string. The operation returns TRUE if the name of the object matches the supplied wildcarded string.
`reftype'(%i)
The identifier for this operation is reftype (FN_ID_STRING). The argument to this operation is an identifier. The operation returns TRUE if the reference type of the object is equal to the supplied identifier.
`addrtype'(%i)
The identifier for this operation is addrtype(FN_ID_STRING). The argument to this operation is an identifier.
The operation returns TRUE if any of the address types in the reference of the object is equal to the supplied identifier. Support and exact semantics of extended operations are context-specific. If a context does not support an extended operation, or if the filter expression supplies the extended operation with either an incorrect number or type of arguments, the error FN_E_SEARCH_INVALID_OP is returned. FN_E_OPERATION_NOT_SUPPORTED is returned when fn_attr_ext_search() is not supported.
Table 2–10 contains examples of filter expressions that contain extended operations.
Table 2–10 Extended Operations in Search Filter Expressions
Expression
Meaning
`name'(`bill'*)
Evaluates to TRUE if the name of the object starts with bill.
%i(%a, %v)
Evaluates to result of applying the specified operation to the supplied arguments.
(%a == %v) and `name'(`joe'*)
Evaluates to TRUE if the specified attribute has the given value and if the name of the object starts with joe.
