Each naming system in an XFN federation has a naming convention. XFN defines a standard model of expressing compound name syntax that covers a large number of specific name syntaxes. This model is expressed in terms of syntax properties of the naming convention and it uses XFN attributes to describe properties of the syntax.
Unless otherwise qualified, the syntax attributes described in this section have attribute identifiers that use the FN_ID_STRING format. This does not specify or restrict the use of other formats for identifiers of additional syntax attributes supported by specific implementations.
In the XFN standard syntax model, these attributes are interpreted according to the following rules:
In a string without quotes or escapes, any instance of the separator string delimits two atomic names.
A separator, quotation mark, or escape string is escaped if preceded immediately (on the left) by the escape string.
A non-escaped begin-quote that precedes a component must be matched by a non-escaped end-quote at the end of the component. Quotes embedded in nonquoted names are treated as simple characters and do not need to be matched. An unmatched quotation fails with the status code FN_E_ILLEGAL_NAME.
If there are multiple values for begin-quote and end-quote, a specific begin-quote value must be matched with its corresponding end-quote value.
When the separator appears between a (nonescaped) begin-quote and the end-quote, it is ignored.
When the separator is escaped, it is not treated as a separator. An escaped begin-quote or end-quote string is not treated as a quotation mark. An escaped escape string is not treated as an escape string.
A non-escaped escape string appearing within quotes is interpreted as an escape string. This can be used to embed an end-quote within a quoted string.
An escape string that precedes a character other than an escape string, a begin-quote or an end-quote is consumed (in other words, escaping a non-meta character returns the non-meta character itself).
After constructing a compound name from a string, the resulting component atoms have one level of escape strings and quotations interpreted and consumed.
Code set mismatches that occur during the construction of the compound name's string form are resolved in an implementation-dependent way. When an implementation discovers that a compound name has components with incompatible code sets, it returns the error code FN_E_INCOMPATIBLE_CODE_SETS. When an implementation discovers that a compound name has components with incompatible language or territory locale information, it returns the error code FN_E_INCOMPATIBLE_LOCALES.
Table 2–11 lists all the XFN standard syntax model attributes.
Table 2–11 XFN Syntax Attributes|
Attribute Identifier |
Attribute Value |
Its value is the ASCII string ”standard” if the context supports the XFN standard syntax model. Its value is an implementation-specific value if another syntax model is supported. |
ax_direction |
Its value is an ASCII string, one of “left-to-right,” “right-to-left,” or “flat.” This determines whether the order of components in a compound name string goes from left-to-right, right-to-left, or whether the namespace is flat (that is, not hierarchical, with all names atomic). |
Its value is the separator string for this name syntax. This attribute is required unless the fn_syntax_direction is flat. |
If present, its value is the escape string for this name syntax. |
If present, it indicates that names differing only in case are considered identical. If this attribute is absent, it indicates that case is significant. If a value is present, it is ignored. |
If present, its value is one of the begin-quote strings for this syntax. If fn_std_syntax_end_quote1 is absent but fn_std_syntax_begin_quote1 is present, the quote-string specified in fn_std_syntax_begin_quote1 is used as both the begin and end quote-strings. If fn_std_syntax_end_quote1 is present but fn_std_syntax_begin_quote1 is absent, the quote-string specified in fn_std_syntax_end_quote1 is used as both the begin and end-quote-strings. |
If present, its value is the end-quote string for this syntax. If fn_std_syntax_end_quote1 is absent but fn_std_syntax_begin_quote1 is present, the quote-string specified in fn_std_syntax_begin_quote1 is used as both the begin and end quote-strings. If fn_std_syntax_end_quote1 is present but fn_std_syntax_begin_quote1 is absent, the quote-string specified in fn_std_syntax_end_quote1 is used as both the begin and end-quote-strings. |
If present, its value is one of the begin-quote strings for this syntax. If fn_std_syntax_end_quote2 is absent but fn_std_syntax_begin_quote2 is present, the quote-string specified in fn_std_syntax_begin_quote2 is used as both the begin and end quote-strings. If fn_std_syntax_end_quote2 is present but fn_std_syntax_begin_quote2 is absent, the quote-string specified in fn_std_syntax_end_quote2 is used as both the begin and end-quote-strings. |
If present, its value is the end-quote string for this syntax. If fn_std_syntax_end_quote2 is absent but fn_std_syntax_begin_quote2 is present, the quote-string specified in fn_std_syntax_begin_quote2 is used as both the begin and end quote-strings. If fn_std_syntax_end_quote2 is present but fn_std_syntax_begin_quote2 is absent, the quote-string specified in fn_std_syntax_end_quote2 is used as both the begin and end-quote-strings. |
If present, its value is the attribute-value assertion separator string for this syntax. |
If present, its value is the attribute type-value separator string for this syntax. |
If present, its value identifies the code sets of the string representation for this syntax. Its value consists of a structure containing an array of code sets supported by the context; the first member of the array is the preferred code set of the context. The values for the code sets are defined in the X/Open code set registry currently defined in DCE RFC 40.1. If this attribute is not present, or if the value is empty, the default code set is ISO 646 (same encoding as ASCII). |
