Get one or more attributes associated with the object named name relative to the context ctx. If name is empty, the attributes associated with ctx are returned.
FN_multigetlist_t *fn_attr_multiget(
FN_ctx_t *ctx,
const FN_composite_name_t *name,
const FN_attrset_t *attr_ids,
unsigned int follow_link,
FN_status_t *status);
FN_attribute_t *fn_multigetlist_next(
FN_multigetlist_t *ml,
void fn_multigetlist_destroy(
FN_multigetlist_t *ml);
The attributes returned are those specified in attr_ids. If the value of attr_ids is 0, all attributes associated with the named object are returned. Any attribute values in attr_ids provided by the caller are ignored; only the identifiers are relevant for this operation. Each attribute (identifier, syntax, and values) is returned one at a time using an enumeration scheme similar to that for listing a context. fn_attr_multi_get() initiates the enumeration process. It returns a handle to an FN_multigetlist_t object that can be used for subsequent fn_multigetlist_next() calls to enumerate the attributes requested.
The operation fn_multigetlist_next() returns the next attribute (identifier, syntax, and values) in the enumeration and updates ml to indicate the state of the enumeration. Successive calls to fn_multigetlist_next() using ml return successive attributes in the enumeration and further update the state of the enumeration.
The operation fn_multigetlist_destroy() frees the resources used during the enumeration. This operation can be invoked at any time to terminate the enumeration.
Implementations are not required to return all attributes requested by attr_ids. Some might choose to return only the attributes found successfully; such implementations might not necessarily return identifiers for attributes that could not be read.
