Federated Naming Service Programming Guide
Parameters Used in Extended Search (Preliminary Specification)
The types of objects used to specify the scope and details of an extended search operation:
Search Control
The FN_search_control_t object encapsulates the different options that the application can specify in controlling the scope and the return values of the extended search operation, fn_attr_ext_search() .
These options are:
Table 2–5 Different Scopes for Searching
Scope
Meaning
FN_SEARCH_NAMED_OBJECT
Search just the given named object.
FN_SEARCH_ONE_CONTEXT
Search just the given context.
FN_SEARCH_SUBTREE
Search given context and all its subcontexts.
FN_SEARCH_CONSTRAINED_SUBTREE
Search given context and its subcontexts as constrained by the context-specific policy in place at the named context.
Search Filter
The fn_attr_ext_search() operation allows the search for named objects whose attributes satisfy a given filter expression. The filter is expressed in terms of logical expressions involving attribute identifiers and their values of named objects examined during the search. The filter is created from an expression string and a list of arguments that replace substitution tokens within the expression string.
BNF of Filter Expression
<FilterExpr> ::=  [ <Expr> ]
 <Expr> ::= <Expr> "or" <Expr>
    | <Expr> "and" <Expr>
    | "not" <Expr>
    | "(" <Expr> ")"
    | <Attribute> [ <Rel_Op> <Value> ]
    | <Ext>
 <Rel_Op> ::= "==" | "!=" | "<" | "<=" | ">" | ">=" | "~="
 <Attribute> ::= "%a"
 <Value> ::= <Integer>
    | "%v"
    | <Wildcarded_string>
 <Wildcarded_string> ::= "*"
    | <String>
    | {<String> "*"}+ [<String>]
    | {"*" <String>}+ ["*"]
 <String> ::= "`" { <Char> } * "`"
    | "%s"
 <Char> ::= <PCS> // See BNF in Section 4.1.2 for PCS definition
    | Characters in the repertoire of a string representation
 <Identifier> ::= "%i"
 <Ext> ::= <Ext_Op> "(" [Arg_List] ")"
 <Ext_Op> ::= <String> | <Identifier>
 <Arg_List> ::= <Arg> | <Arg> "," <Arg_List>
 <Arg> ::= <Value> | <Attribute> | <Identifier>
Specification of Filter Expression
The arguments to fn_search_filter_create() are a return status, an expression string, and a list of arguments. The string contains the filter expression with substitution tokens for the attributes, attribute values, strings and identifiers that are part of the expression. The remaining list of arguments contains the attributes and values in the order of appearance of their corresponding substitution tokens in the expression. The arguments are of types FN_attribute_t*, FN_attrvalue_t*, FN_string_t* or FN_identifier_t*.
Except when attributes appear as arguments in specially defined extended operations, any attribute values in an FN_attribute_t type of argument are ignored; only the attribute identifier and attribute syntax are relevant. The argument type expected by each substitution token is listed in Table 2–6.
Table 2–6 Substitute Tokens in Search Filter Expressions
Token
Argument Type
%a
FN_attribute_t*
%v
FN_attrvalue_t*
%s
FN_string_t*
%i
FN_identifier_t*
Precedence
The following precedence relations hold in the absence of parentheses, in the order of lowest to highest:
These Boolean and relational operators are left associative.
Relational Operators
Table 2–7 contains descriptions of the relational operators. Comparisons and ordering are specific to the syntax or rules of the supplied attribute.
Locale (code set, language or territory) mismatches that occur during string comparisons and ordering operations are resolved in an implementation-dependent way. Relational operations that have ordering semantics may be used for strings of locales in which ordering is meaningful, but is not of general use in internationalized environments.
An attribute that occurs in the absence of any relational operator tests for the presence of the attribute.
Table 2–7 Relational Operators in Search Filter Expressions
Operator
Meaning
The sub-expression is TRUE if at least one value of the specified attribute is equal to the supplied value.
The sub-expression is TRUE if no values of the specified attribute equal the supplied value.
The sub-expression is TRUE if at least one value of the attribute is greater than or equal to the supplied value.
The sub-expression is TRUE if at least one value of the attribute is greater then the supplied value.
The sub-expression is TRUE if at least one value of the attribute is less than or equal to the supplied value.
The sub-expression is TRUE if at least one value of the attribute is less than the supplied value.
The sub-expression is TRUE if at least one value of the specified attribute matches the supplied value according to some context-specific approximate matching criterion. This criterion must subsume strict equality.
Wildcarded Strings
A wildcarded string consists of a sequence of alternating wildcard specifiers and strings. The sequence can start with either a wildcard specifier or a string, and end with either a wildcard specifier or a string.
The wildcard specifier is denoted by the asterisk character (*) and means 0 or more occurrences of any character.
Wildcarded strings can be used to specify substring matches. Table 2–8 contains examples of wildcarded strings and their meaning.
Table 2–8 Examples of Wildcarded Strings
Wildcarded String
Meaning
Any string
`tom'
The string tom
`harv'*
Any string starting with harv
*'ing'
Any string ending with ing
`a'*'b'
Any string starting with a and ending with b
`a*b'
The string a*b
`jo'*'ph'*'ne'*'er'
Any string starting with jo, and containing the substring ph, and which contains the substring ne in the portion of the string following ph, and which ends with er
%s*
Any string starting with the supplied string
`bix'*%s
Any string starting with bix and ending with the supplied string
Extended Operations
In addition to the relational operators, extended operators can be specified. All extended operators return either TRUE or FALSE. A filter expression can contain both relational and extended operations.
Extended operators are specified using an identifier (FN_identifier_t) or a string. If the operator is specified using a string, the string is used to construct an identifier of format FN_ID_STRING. Identifiers of extended operators and signatures of the corresponding extended operations, as well as their suggested semantics, are registered with X/Open.
The extended operations shown in Table 2–9 are currently defined:
Table 2–9 Extended Operations
`name'(<Wildcarded String>)
The identifier for this operation is name(FN_ID_STRING). The argument to this operation is a wildcarded string. The operation returns TRUE if the name of the object matches the supplied wildcarded string.
`reftype'(%i)
The identifier for this operation is reftype (FN_ID_STRING). The argument to this operation is an identifier. The operation returns TRUE if the reference type of the object is equal to the supplied identifier.
`addrtype'(%i)
The identifier for this operation is addrtype(FN_ID_STRING). The argument to this operation is an identifier.
The operation returns TRUE if any of the address types in the reference of the object is equal to the supplied identifier. Support and exact semantics of extended operations are context-specific. If a context does not support an extended operation, or if the filter expression supplies the extended operation with either an incorrect number or type of arguments, the error FN_E_SEARCH_INVALID_OP is returned. FN_E_OPERATION_NOT_SUPPORTED is returned when fn_attr_ext_search() is not supported.
Table 2–10 contains examples of filter expressions that contain extended operations.
Table 2–10 Extended Operations in Search Filter Expressions
Expression
Meaning
`name'(`bill'*)
Evaluates to TRUE if the name of the object starts with bill.
%i(%a, %v)
Evaluates to result of applying the specified operation to the supplied arguments.
(%a == %v) and `name'(`joe'*)
Evaluates to TRUE if the specified attribute has the given value and if the name of the object starts with joe.
