FN_SUCCESS
The operation succeeded.
FN_E_ATTR_IN_USE
When an attribute is being modified using the operation FN_ATTR_OP_ADD_EXCLUSIVE and an attribute with the same identifier already exists, the
operation fails with FN_E_ATTR_IN_USE.
FN_E_ATTR_NO_PERMISSION
The caller did not have permission to perform the attempted
attribute operation.
FN_E_ATTR_VALUE_REQUIRED
The operation attempted to create an attribute without
a value, and the specific naming system does not allow this.
FN_E_AUTHENTICATION_FAILURE
The identity of the client principal could not be verified.
FN_E_COMMUNICATION_FAILURE
An error occurred in communicating with one of the contexts
involved in the operation.
FN_E_CONFIGURATION_ERROR
A problem was detected that indicated an error in the installation
of the XFN interfaces.
FN_E_CONTINUE
The operation should be continued using the remaining name
and the resolved reference returned in the status.
FN_E_CTX_NO_PERMISSION
The client did not have permission to perform the operation.
FN_E_CTX_NOT_EMPTY
Applies only to fn_ctx_destroy_subcontext().
The naming system required that the context be empty before its destruction,
and it was not empty.
FN_E_CTX_UNAVAILABLE
Service could not be obtained from one of the contexts
involved in the operation. This might be because the naming system is busy
or is not providing service. In some implementations this might not be distinguished
from a communication failure.
FN_E_ILLEGAL_NAME
The name supplied to the operation was not a well-formed
composite name, or one of the component names was not well formed according
to the syntax of the naming systems involved in its resolution.
FN_E_INCOMPATIBLE_CODE_SETS
The operation involved character strings of incompatible
code sets or the supplied code set is not supported by the implementation.
FN_E_INCOMPATIBLE_LOCALES
The operation involved character strings of incompatible language or territory
locale information, or the specified locale is not supported by the implementation.
FN_E_INSUFFICIENT_RESOURCES
Either the client or one of the involved contexts could
not obtain sufficient resources (on memory, file descriptors, communication
ports, stable media space, for example) to complete the operation successfully.
FN_E_INVALID_ATTR_IDENTIFIER
The attribute identifier was not in a format acceptable to the naming system,
or its contents were not valid for the format specified for the identifier.
FN_E_INVALID_ATTR_VALUE
One of the values supplied was not in the appropriate form
for the given attribute.
FN_E_INVALID_ENUM_HANDLE
The enumeration handle supplied was invalid, either because
it was from another enumeration, because an update operation occurred during
the enumeration, or for some other reason.
FN_E_INVALID_SYNTAX_ATTRS
The syntax attributes supplied are invalid or insufficient
to fully specify the syntax.
FN_E_LINK_ERROR
An error occurred while resolving an XFN link encountered
during resolution of the supplied name.
FN_E_LINK_LOOP_LIMIT
A nonterminating loop (cycle) in the resolution is suspected.
This arises due to XFN links encountered during the resolution of a supplied
composite name. This code indicates either the definite detection of such
a cycle, or that resolution exceeded an implementation-defined limit on the
number of XFN links allowed for a single operation invoked by the caller (and
thus a cycle is suspected).
FN_E_MALFORMED_LINK
A malformed link reference was encountered. For fn_ctx_lookup_link(), the name supplied resolved to a reference that
was not a link.
FN_E_MALFORMED_REFERENCE
A context object could not be constructed from the supplied
reference because the reference was not properly formed.
FN_E_NAME_IN_USE
(Only for operations that bind names.) The supplied name
was already in use.
FN_E_NAME_NOT_FOUND
Resolution of the supplied composite name proceeded to
a context in which the next atomic component of the name was not bound.
FN_E_NO_EQUIVALENT_NAME
No equivalent name can be constructed, either because there is no meaningful
equivalence between name and leading_name,
or the system does not support constructing the requested equivalent name,
for implementation-specific reasons.
FN_E_NO_SUCH_ATTRIBUTE
The object does not have an attribute with the given identifier.
FN_E_NO_SUPPORTED_ADDRESS
A context object could not be constructed from a particular
reference. The reference contained no address type over which the context
interface was supported.
FN_E_NOT_A_CONTEXT
Either one of the intermediate atomic names did not name
a context, and resolution could not proceed beyond this point, or the operation
required that the caller supply the name of a context, and the name did not
resolve to a reference for a context.
FN_E_OPERATION_NOT_SUPPORTED
The operation attempted is not supported.
FN_E_PARTIAL_RESULT
The operation attempted is returning a partial result.
FN_E_SEARCH_INVALID_FILTER
The filter expression had a syntax error or some other problem.
FN_E_SEARCH_INVALID_OP
An operator in the filter expression is not supported or, if the operator
is an extended operator, the number of types of arguments supplied does not
match the signature of the operation.
FN_E_SEARCH_INVALID_OPTION
A supplied search control option could not be supported.
FN_E_SYNTAX_NOT_SUPPORTED
The syntax type specified is not supported.
FN_E_TOO_MANY_ATTR_VALUES
The operation attempted to associate more values with an
attribute than the naming system supported.
FN_E_UNSPECIFIED_ERROR
An error occurred that could not be classified by any of
the other error codes.
