The Federated Naming Service (FNS) is a set of application programming interfaces and policies that allow applications to use a common set of names and policies over different name services.
FNS is implemented on top of NIS+ and allows you to use a set of common names with desktop applications. Sun's implementation of FNS conforms to the X/OpenTM federated naming (XFN) specification.
The primary audience of Federated Naming Service Guide is software developers who write distributed applications. Use of this guide assumes basic competence in programming, a working familiarity with the C programming language, and a working familiarity with the UNIX® operating system. Developers should read all four parts of this manual.
System and network administrators should look at System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP) for FNS setup and configuration, as well as administration information. This manual does not cover NIS or the Domain Name System (DNS) except as they relate to FNS. For information on all other Solaris operating environment naming and directory services, please refer to the System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP).
Chapter 1, Introduction to the Federated Naming Service (FNS) is a high-level overview of FNS and the problems it addresses.
Chapter 2, Interfaces for Writing XFN Applications describes the client programming interfaces for X/Open Federated Naming (XFN).
Chapter 3, XFN Programming Examples presents three self-contained executable programs: a namespace browser, a printer client and server, and a tool to populate attributes of users.
Appendix A, XFN Composite Names describes the XFN composite name string syntax and the resolution techniques for composite names.
Appendix B, XFN Composite Names Syntax gives supplemental information about composite name syntax.
With the exception of the XFN specification, the following books do not specifically cover FNS but they provide a good background on how name services work in client-server computing:
Raman Khanna. Distributed Computing—Implementation and Strategy. Prentice Hall, 1993
Sape J. Mullender (editor).Distributed Systems. ACM Press, 1990
P. Albitz and C. Liu.DNS and BIND. O`Reilly, 1992
Managing the X.500 Client Toolkit. SunSoft Inc., 1995
X/Open Preliminary Specifications, Federated Naming: The XFN Specifications. X/Open Document #P403, ISBN: 1-85912-045-8. X/Open, July 1994
You may also want to reference the following AnswerBook® on-line documentation:
Solaris Reference Manual Collection
Solaris Software Developer Collection
The docs.sun.comSM Web site enables you to access Sun technical documentation online. You can browse the docs.sun.com archive or search for a specific book title or subject. The URL is http://docs.sun.com.
The following table describes the typographic changes used in this book.
Table P–1 Typographic Conventions|
Typeface or Symbol |
Meaning |
Example |
AaBbCc123 | The names of commands, files, and directories; on-screen computer output |
Edit your .login file. Use ls -a to list all files. machine_name% you have mail. |
AaBbCc123 | What you type, contrasted with on-screen computer output |
machine_name% su Password: |
AaBbCc123 | Command-line placeholder: replace with a real name or value |
To delete a file, type rm filename. |
AaBbCc123 |
Book titles, new words, or terms, or words to be emphasized. |
Read Chapter 6 in User's Guide. These are called class options. You must be root to do this. |
The following table shows the default system prompt and superuser prompt for the C shell, Bourne shell, and Korn shell.
Table P–2 Shell Prompts|
Shell |
Prompt |
| C shell prompt | machine_name% |
| C shell superuser prompt | machine_name# |
| Bourne shell and Korn shell prompt | $ |
| Bourne shell and Korn shell superuser prompt | # |
