Federated Naming Service Programming Guide
XFN Backus-Naur Form (BNF)
The following defines the standard string form of XFN composite names in Backus-Naur Form (BNF). All the characters of the string representation of one name must uniformly use the same encoding and locale information. The notations used are shown in Table B–1:
Table B–1 Backus-Naur Notation
Symbol
Meaning
Is defined to be
Alternatively
<text>
Nonterminal element
Literal expression
The preceding syntactic unit can appear 0 or more times.
The preceding syntactic unit can appear 1 or more times.
The enclosed syntactic units are grouped as a single syntactic unit (can be nested).
The XFN composite name syntax in BNF is shown in Table B–2:
Table B–2 XFN Composite Name Syntax Using BNF
XFN Composite Name
BNF Syntax
NULL ::=
// Empty set
<PCS> ::=
// Portable Character Set.
The set consists of the glyphs:
//!"#$%&'()*+,\0123456789:;<=>?
//@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\]^_'
//abcdefghijklmnopqrstuvwxyz{|}~
<CharSet> ::=
<PCS>
| Characters from the repertoire of a string representation
<EscapeChar> ::=
<ComponentSep>::=
<Quote1>::=
<Quote2> ::=
<MetaChar> ::=
<EscapeChar> | <ComponentSep>
<SimpleChar> ::=
// any character from <CharSet> with <MetaChar>, <Quote1>,
// and <Quote2> excluded. An<EscapeChar> <MetaChar>, or
// <EscapeChar> <Quote1>, or <EscapeChar> <Quote2> is equivalent to
// <SimpleChar>.
<Component> ::=
<SimpleChar>*
| <SimpleChar>+ {<Quote1> |  <Quote2> | <SimpleChar>}*
| <Quote1> <CharSet>* {<EscapeChar> <Quote1>}* <Quote1>
 // <CharSet> must not contain unescaped <Quote1>
 // (note that <Quote2> can appear unescaped)
| <Quote2> <CharSet>* {<EscapeChar> <Quote2>}* <Quote2>
 // <CharSet> must not contain unescaped <Quote2>
 // (note that <Quote1> can appear unescaped)
<CompositeName> ::=
NULL
| <Component> {<ComponentSep> <Component>}*
