This example shows how to use the following pseudo-ops to specify the bindings of variables in C:
common, .global, .local, .weak
The following C definitions/declarations:
int foo1 = 1; #pragma weak foo2 = foo1 static int foo3; static int foo4 = 2;
can be translated into the following assembly code:
.pushsection ".data"
.global foo1 ! int foo1 = 1
.align 4
foo1:
.word 0x1
.type foo1,#object ! foo1 is of type data object,
.size foo1,4 ! with size = 4 bytes
.weak foo2 ! #pragma weak foo2 = foo1
foo2 = foo1
.local foo3 ! static int foo3
.common foo3,4,4
.align 4 ! static int foo4 = 2
foo4:
.word 0x2
.type foo4,#object
.size foo4,4
.popsection
