The pseudo-ops shown in this example are .align, .global, .type, and .size.
The following C subroutine:
int sum(a, b)
int a, b;
return(a + b);
can be translated into the following assembly code:
.section ".text" .global sum .align 4 sum: retl add %o0,%o1,%o0 ! (a + b) is done in the ! delay slot of retl .type sum,#function ! sum is of type function .size sum,.-sum ! size of sum is the diff ! of current location ! counter and the initial ! definition of sum
