The type of object files created by the SPARC assembler version for SunOS 5.x are now Executable and Linking Format (ELF) files. These relocatable ELF files hold code and data suitable for linking with other object files to create an executable or a shared object file, and are the assembler normal output. The assembler can also write information to standard output (for example, under the -S option) and to standard error (for example, under the -V option). The SPARC assembler creates a default output file when standard input or multiple files are used.
This chapter is organized into the following sections:
The ELF object file format consists of:
Header
Sections
Locations
Addresses
Relocation tables
Symbol tables
String tables
For more information, see the System V Application Binary Interface: SPARCTM Processor Supplement.
The ELF header is always located at the beginning of the ELF file. It describes the ELF file organization and contains the actual sizes of the object file control structures. The initial bytes of an ELF header specify how the file is to be interpreted.
The ELF header contains the following information:
entry
Virtual address at which the process is to start. A value of 0 indicates no associated entry point.
ident
Marks the file as an object file and provides machine-independent data to decode and interpret the file contents.
phnum
Number of entries in program header table. A value of 0 indicates the file has no program header table.
shentsize
Size in bytes of the section header. A section header is one entry in the section header table; all entries are the same size.
shnum
Number of entries in section header table. A value of 0 indicates the file has no section header table.
shstrndx
Section header table index of the entry associated with the section name string table. A value of SHN_UNDEF indicates the file does not have a section name string table.
type
Identifies the object file type. Table 3–1 describes the reserved object file types.
Table 3–1 shows reserved object file types:
Table 3–1|
Type |
Value |
Description |
none |
0 |
No file type |
rel |
1 |
Relocatable file |
exec |
2 |
Executable file |
dyn |
3 |
Shared object file |
core |
4 |
Core file |
loproc |
0xff00 |
Processor-specific |
hiproc |
0xffff |
A section is the smallest unit of an object that can be relocated. The following sections are commonly present in an ELF file:
Section header
Executable text
Read-only data
Read-write data
Read-write uninitialized data (section header only)
Sections do not need to be specified in any particular order. The current section is the section to which code is generated.
These sections contain all other information in an object file and satisfy several conditions.
Every section must have one section header describing the section. However, a section header does not need to be followed by a section.
Each section occupies one contiguous sequence of bytes within a file. The section may be empty (that is, of zero-length).
A byte in a file can reside in only one section. Sections in a file cannot overlap.
An object file may have inactive space. The contents of the data in the inactive space are unspecified.
Sections can be added for multiple text or data segments, shared data, user-defined sections, or information in the object file for debugging.
Not all of the sections need to be present.
The section header allows you to locate all of the file sections. An entry in a section header table contains information characterizing the data in a section.
The section header contains the following information:
addr
Address at which the first byte resides if the section appears in the memory image of a process; the default value is 0.
addralign
Aligns the address if a section has an address alignment constraint; for example, if a section contains a double-word, the entire section must be ensured double-word alignment. Only 0 and positive integral powers of 2 are currently allowed. A value of 0 or 1 indicates no address alignment constraints.
entsize
Size in bytes for entries in fixed-size tables such as the symbol table.
flags
One-bit descriptions of section attributes. Table 3–2 describes the section attribute flags.
Flag |
Default Value |
Description |
SHF_WRITE |
0x1 |
Contains data that is writable during process execution. |
SHF_ALLOC |
0x2 |
Occupies memory during process execution. This attribute is off if a control section does not reside in the memory image of the object file. |
SHF_EXECINSTR |
0x4 |
Contains executable machine instructions. |
SHF_MASKPROC |
0xf0000000 |
Reserved for processor-specific semantics. |
info
Extra information. The interpretation of this information depends on the section type, as described in Table 3–3.
link
Section header table index link. The interpretation of this information depends on the section type, as described in Table 3–3.
name
Specifies the section name. An index into the section header string table section specifies the location of a null-terminated string.
offset
Specifies the byte offset from the beginning of the file to the first byte in the section.
If the section type is SHT_NOBITS, offset specifies the conceptual placement of the file.
size
Specifies the size of the section in bytes.
If the section type is SHT_NOBITS, size may be non-zero; however, the section still occupies no space in the file.
type
Categorizes the section contents and semantics. Table 3–3 describes the section types.
Name
Value
Description
Interpretation by |
info |
link |
null |
0 |
Marks section header as inactive. |
progbits |
1 |
Contains information defined explicitly by the program. |
symtab |
2 |
Contains a symbol table for link editing. This table may also be used for dynamic linking; however, it may contain many unnecessary symbols. Note: Only one section of this type is allowed in a file |
One greater than the symbol table index of the last local symbol. |
The section header index of the associated string table. |
strtab |
3 |
Contains a string table. A file may have multiple string table sections. |
rela |
4 |
Contains relocation entries with explicit addends. A file may have multiple relocation sections. |
The section header index of the section to which the relocation applies. |
The section header index of the associated symbol table. |
hash |
5 |
Contains a symbol rehash table. Note: Only one section of this type is allowed in a file |
0 |
The section header index of the symbol table to which the hash table applies. |
dynamic |
6 |
Contains dynamic linking information. Note: Only one section of this type is allowed in a file |
0 |
The section header index of the string table used by entries in the section. |
note |
7 |
Contains information that marks the file. |
nobits |
8 |
Contains information defined explicitly by the program; however, a section of this type does not occupy any space in the file. |
rel |
9 |
Contains relocation entries without explicit addends. A file may have multiple relocation sections. |
shlib |
10 |
Reserved. |
dynsym |
11 |
Contains a symbol table with a minimal set of symbols for dynamic linking. Note: Only one section of this type is allowed in a file |
loproc hiproc |
0x70000000 0x7fffffff |
Lower and upper bound of range reserved for processor-specific semantics. |
louser hiuser |
0x80000000 0xffffffff |
Lower and upper bound of range reserved for application programs. Note: Section types in this range may be used by an application without conflicting with system-defined section types. |
Some section header table indexes are reserved and the object file will not contain sections for these special indexes.
A section that can be manipulated by the section control directives is known as a user section. You can use the section control directives to change the user section in which code or data is generated. Table 3–4 lists the predefined user sections that can be named in the section control directives.
Table 3–4|
Section Name |
Description |
.bss |
Section contains uninitialized read-write data. |
.comment |
Comment section. |
.data & .data1 |
Section contains initialized read-write data. |
.debug |
Section contains debugging information. |
.fini |
Section contains runtime finalization instructions. |
.init |
Section contains runtime initialization instructions. |
.rodata & .rodata1 |
Section contains read-only data. |
.text |
Section contains executable text. |
.line |
Section contains line # info for symbolic debugging. |
.note |
Section contains note information. |
The .init sections contain codes that are to be executed before the the main program is executed. To create an .init section in an object file, use the assembler pseudo-ops shown in Example 3–1.
.section ".init" .align 4 <instructions>
At link time, the .init sections in a sequence of .o files are concatenated into an .init section in the linker output file. The code in the .init section are executed before the main program is executed.
Because the whole .init section is treated as a single function body, it is recommented that the only code added to these sections be in the following form:.
call routine_name
nop |
The called routine should be located in another section. This will prevent conflicting register and stack usage within the .init sections.
.fini sections contain codes that are to be executed after the the main program is executed. To create an .fini section in an object file, use the assembler pseudo-ops shown in Example 3–2.
.section ".fini" .align 4 <instructions>
At link time, the .fini sections in a sequence of .o files are concatenated into a .fini section in the linker output file. The codes in the .fini section are executed after the main program is executed.
Because the whole .fini section is treated as a single function body, it is recommended that the only code added to these section be in the following form:.
call routine_name
nop |
The called routine should be located in another section. This will prevent conflicting register and stack usage within the .fini sections.
Table 3–5 lists sections that are predefined but cannot be named in the section control directives because they are not under user control.
Table 3–5|
Section Name |
Description |
".dynamic" |
Section contains dynamic linking information. |
.dynstr |
Section contains strings needed for dynamic linking. |
.dynsym |
Section contains the dynamic linking symbol table. |
.got |
Section contains the global offset table. |
.hash |
Section contains a symbol hash table. |
.interp |
Section contains the path name of a program interpreter. |
.plt |
Section contains the procedure linking table. |
.relname & .relaname |
Section containing relocation information. name is the section to which the relocations apply, that is, ".rel.text", ".rela.text". |
.shstrtab |
String table for the section header table names. |
.strtab |
Section contains the string table. |
.symtab |
Section contains a symbol table. |
A location is a specific position within a section. Each location is identified by a section and a byte offset from the beginning of the section. The current location is the location within the current section where code is generated.
A location counter tracks the current offset within each section where code or data is being generated. When a section control directive (for example, the .section pseudo-op) is processed, the location information from the location counter associated with the new section is assigned to and stored with the name and value of the current location.
The current location is updated at the end of processing each statement, but can be updated during processing of data-generating assembler directives (for example, the .word pseudo-op).
Each section has one location counter; if more than one section is present, only one location can be current at any time.
Locations represent addresses in memory if a section is allocatable; that is, its contents are to be placed in memory at program runtime. Symbolic references to these locations must be changed to addresses by the SPARC link editor.
The assembler produces a companion relocation table for each relocatable section. The table contains a list of relocations (that is, adjustments to data in the section) to be performed by the link editor.
A symbol table contains information to locate and relocate symbolic definitions and references. The SPARC assembler creates a symbol table section for the object file. It makes an entry in the symbol table for each symbol that is defined or referenced in the input file and is needed during linking. The symbol table is then used by the SPARC link editor during relocation. The section header contains the symbol table index for the first non-local symbol.
A symbol table contains the following information:
name
Index into the object file symbol string table. A value of zero indicates the symbol table entry has no name; otherwise, the value represents the string table index that gives the symbol name.
value
Value of the associated symbol. This value is dependent on the context; for example, it may be an address, or it may be an absolute value.
size
Size of symbol. A value of 0 indicates that the symbol has either no size or an unknown size.
info
Specifies the symbol type and binding attributes. Table 3–6 and Table 3–7 describe these values.
other
shndx
Contains the section header table index to another relevant section, if specified. As a section moves during relocation, references to the symbol will continue to point to the same location because the value of the symbol will change as well.
Value |
Type |
Description |
0 |
notype |
Type not specified. |
1 |
object |
Symbol is associated with a data object; for example, a variable or an array. |
2 |
func |
Symbol is associated with a function or other executable code. When another object file references a function from a shared object, the link editor automatically creates a procedure linkage table entry for the referenced symbol. |
3 |
section |
Symbol is associated with a section. These types of symbols are primarily used for relocation. |
4 |
file |
Gives the name of the source file associated with the object file. |
13 15 |
loproc hiproc |
Values reserved for processor-specific semantics. |
Table 3–7 shows the symbol binding attributes.
Table 3–7|
Value |
Binding |
Description |
0 |
local |
Symbol is defined in the object file and not accessible in other files. Local symbols of the same name may exist in multiple files. |
1 |
global |
Symbol is either defined externally or defined in the object file and accessible in other files. |
2 |
weak |
Symbol is either defined externally or defined in the object file and accessible in other files; however, these definitions have a lower precedence than globally defined symbols. |
13 15 |
loproc hiproc |
A string table is a section which contains null-terminated variable-length character sequences, or strings, in the object file; for example, symbol names and file names. The strings are referenced in the section header as indexes into the string table section.
A string table index may refer to any byte in the section.
Empty string table sections are permitted; however, the index referencing this section must contain zero.
A string may appear multiple times and may also be referenced multiple times. References to substrings may exist, and unreferenced strings are allowed.
Assembler directives, or pseudo-operations (pseudo-ops), are commands to the assembler that may or may not result in the generation of code. The different types of assembler directives are:
Section Control Directives
Symbol Attribute Directives
Assignment Directives
Data Generating Directives
Optimizer Directives
See Appendix A, Pseudo-Operations for a complete description of the pseudo-ops supported by the SPARC assembler.
When a section is created, a section header is generated and entered in the ELF object file section header table. The section control pseudo-ops allow you to make entries in this table. Sections that can be manipulated with the section control directives are known as user sections. You can also use the section control directives to change the user section in which code or data is generated.
The symbol table, relocation table, and string table sections are created implicitly. The section control pseudo-ops cannot be used to manipulate these sections.
The section control directives also create a section symbol which is associated with the location at the beginning of each created section. The section symbol has an offset value of zero.
The symbol attribute pseudo-ops declare the symbol type and size and whether it is local or global.
The assignment directive associates the value and type of expression with the symbol and creates a symbol table entry for the symbol. This directive constitutes a definition of the symbol and, therefore, must be the only definition of the symbol.
The data generating directives are used for allocating storage and loading values.
