SPARC Assembly Language Reference Manual
Appendix E SPARC-V9 Instruction Set
This appendix describes changes made to the SPARC instruction set due to the SPARC-V9 architecture. Application software for the 32-bit SPARC-V8 (Version8) architecture can execute, unchanged, on SPARC-V9 systems.
This appendix is organized into the following sections:
E.1 SPARC-V9 Changes
The SPARC-V9 architecture differs from SPARC-V8 architecture in the following areas, expanded below: registers, alternate space access, byte order, and instruction set.
E.1.1 Registers
These registers have been deleted:
Table E–1
PSR
Processor State Register
TBR
Trap Base Register
WIM
Window Invalid Mask
These registers have been widened from 32 to 64 bits:
Table E–2
Integer registers
All state registers
FSR, PC, nPC, and Y
Note –
FSR Floating-Point State Register: fcc1, fcc2, and fcc3 (added floating-point condition code) bits are added and the register widened to 64-bits.
These SPARC-V9 registers are within a SPARC-V8 register field:
Table E–3
CCR
Condition Codes Register
CWP
Current Window Pointer
PIL
Processor Interrupt Level
TBA
Trap Base Address
TT[MAXTL]
Trap Type
VER
Version
These are registers that have been added.
Table E–4
ASI
Address Space Identifier
CANRESTORE
Restorable Windows
CANSAVE
Savable windows
CLEANWIN
Clean Windows
FPRS
Floating-point Register State
OTHERWIN
Other Windows
PSTATE
Processor State
TICK
Hardware clock tick-counter
TL
Trap Level
TNPC[MAXTL]
Trap Next Program Counter
TPC[MAXTL]
Trap Program Counter
TSTATE[MAXTL]
Trap State
WSTATE
Windows State
Also, there are sixteen additional double-precision floating-point registers, f[32] .. f[62]. These registers overlap (and are aliased with) eight additional quad-precision floating-point registers, f[32] .. f[60]
The SPARC-V9, CWP register is decremented during a RESTORE instruction, and incremented during a SAVE instruction. This is the opposite of PSR.CWP's behavior in SPARC-V8. This change has no effect on nonprivileged instructions.
E.1.2 Alternate Space Access
Load- and store-alternate instructions to one-half of the alternate spaces can now be included in user code. In SPARC-V9, loads and stores to ASIs 0016 .. 7f16 are privileged; those to ASIs 8016 .. FF16 are nonprivileged. In SPARC-V8, access to alternate address spaces is privileged.
E.1.3 Byte Order
SPARC-V9 supports both little- and big-endian byte orders for data accesses only; instruction accesses are always performed using big-endian byte order. In SPARC-V8, all data and instruction accesses are performed in big-endian byte order.
E.2 SPARC-V9 Instruction Set Changes
Application software written for the SPARC-V8 processor runs unchanged on a SPARC-V9 processor.
E.2.1 Extended Instruction Definitions to Support the 64-bit Model
Table E–5
FCMP, FCMPE
Floating-Point Compare—can set any of the four floating-point condition codes.
LDFSR, STFSR
Load/Store FSR- only affect low-order 32 bits of FSR
LDUW, LDUWA
Same as LD, LDA in SPARC-V8
RDASR/WRASR
Read/Write State Registers - access additional registers
SAVE/RESTORE
SETHI
SRA, SRL, SLL, Shifts
Split into 32-bit and 64-bit versions
Tcc
(was Ticc) Operates with either the 32-bit integer condition codes (icc), or the 64-bit integer condition codes (xcc)
All other arithmetic operations operate on 64-bit operands and produce 64-bit results.
E.2.2 Added Instructions to Support 64 bits
Table E–6
F[sdq]TOx
Convert floating point to 64-bit word
FxTO[sdq]
Convert 64-bit word to floating point
FMOV[dq]
Floating-Point Move, double and quad
FNEG[dq]
Floating-point Negate, double and quad
FABS[dq]
Floating-point Absolute Value, double and quad
LDDFA, STDFA, LDFA, STFA
Alternate address space forms of LDDF, STDF, LDF, and STF
LDSW
Load a signed word
LDSWA
Load a signed word from an alternate space
LDX
Load an extended word
LDXA
Load an extended word from an alternate space
LDXFSR
Load all 64 bits of the FSR register
STX
Store an extended word
STXA
Store an extended word into an alternate space
STXFSR
Store all 64 bits if the FSR register
E.2.3 Added Instructions to Support High-Performance System Implementation
Table E–7
BPcc
Branch on integer condition code with prediction
BPr
Branch on integer register contents with prediction
CASA, CASXA
Compare and Swap from an alternate space
FBPfcc
Branch on floating-point condition code with prediction
FLUSHW
Flush windows
FMOVcc
Move floating-point register if condition code is satisfied
FMOVr
Move floating-point register if integer register satisfies condition
LDQF(A), STQF(A)
Load/Store Quad Floating-point (in an alternate space)
MOVcc
Move integer register if condition code is satisfied
MOVr
Move integer register if register contents satisfy condition
MULX
Generic 64-bit multiply
POPC
Population count
PREFETCH, PREFETCHA
Prefetch Data
SDIVX, UDIVX
Signed and Unsigned 64-bit divide
E.2.4 Deleted Instructions
Table E–8
Coprocessor loads and stores
RDTBR and WRTBR
TBR no longer exists. It is replaced by TBA, which can be read/written with RDPR/WRPR instructions
RDWIM and WRWIM
WIM no longer exists. WIM has been replaced by several register-window registers
REPSR and WRPSR
PSR no longer exists. It has been replaced by several separate registers that are read/written with other instructions
RETT
Return from trap (replace by DONE/RETRY)
STDFQ
Store Double from Floating-point Queue (replaced by the RDPR FQ instruction
E.2.5 Miscellaneous Instruction Changes
Table E–9
IMPDEPn
(Changed) Implementation-dependent instructions (replace SPARC-V8 CPop instructions)
MEMBAR
(Added) Memory barrier (memory synchronization support)
E.3 SPARC-V9 Instruction Set Mapping
Table E–10
Opcode
Mnemonic
Argument List
Operation
Comments
BPA
ba{,a}
{,pt|,pn}
%icc or %xcc, label
(Branch on cc with prediction)
Branch always
1
BPN
bn{,a}
{,pt|,pn}
%icc or %xcc, label
Branch never
0
BPNE
bne{,a}
{,pt|,pn}
%icc or %xcc, label
Branch on not equal
not Z
BPE
be{,a}
{,pt|,pn}
%icc or %xcc, label
Branch on equal
BPG
bg{,a}
{,pt|,pn}
%icc or %xcc, label
Branch on greater
not (Z or (N xor V))
BPLE
ble{,a}
{,pt|,pn}
%icc or %xcc, label
Branch on less or equal
Z or (N xor V)
BPGE
bge{,a}
{,pt|,pn}
%icc or %xcc, label
Branch on greater or equal
not (N xor V)
BPL
bl{,a}
{,pt|,pn}
%icc or %xcc, label
Branch on less
N xor V
BPGU
bgu{,a}
{,pt|,pn}
%icc or %xcc, label
Branch on greater unsigned
not (C or Z)
BPLEU
bleu{,a}
{,pt|,pn}
%icc or %xcc, label
Branch on less or equal unsigned
C or Z
BPCC
bcc{,a}
{,pt|,pn}
%icc or %xcc, label
Branch on carry clear (greater than or equal, unsigned)
not C
BPCS
bcs{,a}
{,pt|,pn}
%icc or %xcc, label
Branch on carry set (less than, unsigned)
C
BPPOS
bpos{,a}
{,pt|,pn}
%icc or %xcc, label
Branch on positive
not N
BPNEG
bneg{,a}
{,pt|,pn}
%icc or %xcc, label
Branch on negative
N
BPVC
bvc{,a}
{,pt|,pn}
%icc or %xcc, label
Branch on overflow clear
not V
BPVS
bvs{,a}
{,pt|,pn}
%icc or %xcc, label
Branch on overflow set
BRZ
brz{,a}
{,pt|,pn}
regrs1, label
Branch on register zero
Z
BRLEZ
brlez{,a}
{,pt|,pn}
regrs1, label
Branch on register less than or equal to zero
N or Z
BRLZ
brlz{,a}
{,pt|,pn}
regrs1, label
Branch on register less than zero
N
BRNZ
brnz{,a}
{,pt|,pn}
regrs1, label
Branch on register not zero
not Z
BRGZ
brgz{,a}
{,pt|,pn}
regrs1, label
Branch on register greater than zero
not (N or Z)
BRGEZ
brgez{,a}
{,pt|,pn}
regrs1, label
Branch on register greater than or equal to zero
not N
CASA
casa
casa
[regrs1]imm_asi,regrs2,regrd
[regrs1]%asi,regrs2,regrd
Compare and swap word from alternate space
CASXA
casxa
casxa
Compare and swap extended from alternate space
FBPA
fba{,a}
{,pt|,pn}
%fccn, label
Branch never
1
FBPN
fbn{,a}
{,pt|,pn}
%fccn, label
Branch always
0
FBPU
fbu{,a}
{,pt|,pn}
%fccn, label
Branch on unordered
U
FBPG
fbg{,a}
{,pt|,pn}
%fccn, label
Branch on greater
G
FBPUG
fbug{,a}
{,pt|,pn}
%fccn, label
Branch on unordered or greater
G or U
FBPL
fbl{,a}
{,pt|,pn}
%fccn, label
Branch on less
L
FBPUL
fbul{,a}
{,pt|,pn}
%fccn, label
Branch on unordered or less
L or U
FBPLG
fblg{,a}
{,pt|,pn}
%fccn, label
Branch on less or greater
L or G
FBPNE
fbne{,a}
{,pt|,pn}
%fccn, label
Branch on not equal
L or G or U
FBPE
fbe{,a}
{,pt|,pn}
%fccn, label
Branch on equal
E
FBPUE
fbue{,a}
{,pt|,pn}
%fccn, label
Branch on unordered or equal
E or U
FBPGE
fbge{,a}
{,pt|,pn}
%fccn, label
E or G
FBPUGE
fbuge{,a}
{,pt|,pn}
%fccn, label
Branch on unordered or greater or equal
E or G or U
FBPLE
fble{,a}
{,pt|,pn}
%fccn, label
E or L
FBPULE
fbule{,a}
{,pt|,pn}
%fccn, label
Branch on unordered or less or equal
E or L or u
FBPO
fbo{,a}
{,pt|,pn}
%fccn, label
Branch on ordered
E or L or G
FLUSHW
flushw
Flush register windows
FMOVA
fmov
{s,d,q}a
%icc or %xcc, fregrs2, fregrd
(Move on integer cc)
Move always
1
FMOVN
fmov
{s,d,q}n
Move never
0
FMOVNE
fmov
{s,d,q}ne
Move if not equal
not Z
FMOVE
fmov
{s,d,q}e
Move if equal
Z
FMOVG
fmov
{s,d,q}g
Move if greater
FMOVLE
fmov
{s,d,q}le
Move if less or equal
Z or (N xor V)
FMOVGE
fmov
{s,d,q}ge
Move if greater or equal
not (N xor V)
FMOVL
fmov
{s,d,q}l
Move if less
N xor V
FMOVGU
fmov
{s,d,q}gu
Move if greater unsigned
not (C or Z)
FMOVLEU
fmov
{s,d,q}leu
Move if less or equal unsigned
C or Z
FMOVCC
fmov
{s,d,q}cc
Move if carry clear (greater or equal, unsigned)
not C
FMOVCS
fmov
{s,d,q}cs
Move if carry set (less than, unsigned)
C
FMOVPOS
fmov
{s,d,q}pos
Move if positive
not N
FMOVNEG
fmov
{s,d,q}neg
Move if negative
N
FMOVVC
fmov
{s,d,q}vc
Move if overflow clear
not V
FMOVVS
fmov
{s,d,q}vs
Move if overflow set
V
FMOVRZ
fmovr
{s,d,q}e
regrs1, fregrs2, fregrd
(Move f-p register on cc)
Move if register zero
FMOVRLEZ
fmovr
{s,d,q}lz
Move if register less than or equal zero
FMOVRLZ
fmovr
{s,d,q}lz
Move if register less than zero
FMOVRNZ
FMOVRGZ
FMOVRGEZ
fmovr
{s,d,q}ne
fmovr
{s,d,q}gz
fmovr
{s,d,q}gez
Move if register not zero
Move if register greater than zero
Move if register greater than or equal to zero
FMOVFA
FMOVFN
FMOVFU
FMOVFG
FMOVFUG
FMOVFL
FMOVFUL
FMOVFLG
FMOVFNE
FMOVFE
FMOVFUE
FMOVFGE
FMOVFUGE
FMOVFLE
FMOVFULE
FMOVFO
fmov{s,d,q}a
fmov{s,d,q}n
fmov{s,d,q}u
fmov{s,d,q}g
fmov{s,d,q}ug
fmov{s,d,q}l
fmov{s,d,q}ul
fmov{s,d,q}lg
fmov{s,d,q}ne
fmov{s,d,q}e
fmov{s,d,q}ue
fmov{s,d,q}ge
fmov{s,d,q}uge
fmov{s,d,q}le
fmov{s,d,q}ule
fmov{s,d,q}o
%fccn,fregrs2,fregrd
(Move on floating-point cc)
Move always
Move never
Move if unordered
Move if greater
Move if unordered or greater
Move if less
Move if unordered or less
Move if less or greater
Move if not equal
Move if equal
Move if unordered or equal
Move if unordered or greater or equal
Move if unordered or less or equal
Move if ordered
1
0
U
G
G or U
L
L or U
L or G
L or G or U
E
E or U
E or G
E or G or U
E or L
E or L or u
E or L or G
LDSW
LDSWA
ldsw
ldsw
[address], regrd
[regaddr] imm_asi, regrd
Load a signed word
Load signed word from alternate space
LDX
LDXA
LDXFSR
ldx
ldxa
ldxa
ldx
[address], regrd
[reg_plus_imm] %asi, regrd
[address], %fsr
Load extended word
Load extended word from alternate space
Load floating-point state register
MEMBAR
membar
membar_mask
Memory barrier
MOVA
MOVN
MOVNE
MOVE
MOVG
MOVLE
MOVGE
MOVL
MOVGU
MOVLEU
MOVCC
MOVCS
MOVPOS
MOVNEG
MOVVC
MOVVS
mova
movn
movne
move
movg
movle
movge
movl
movgu
movleu
movcc
movcs
movpos
movneg
movvc
movvs
%icc or %xcc, reg_or_imm11, regrd
(Move integer register on cc)
Move always
Move never
Move if not equal
Move if equal
Move if greater
Move if less
Move if positive
Move if negative
1
0
not Z
Z
Z or (N xor V)
not (N xor V)
N xor V
not (C or Z)
C or Z
not C
C
not N
N
not V
MOVFA
MOVFN
MOVFU
MOVFG
MOVFUG
MOVFL
MOVFUL
MOVFLG
MOVFNE
MOVFE
MOVFUE
MOVFGE
MOVFUGE
MOVFLE
MOVFULE
MOVFO
mova
movn
movu
movg
movug
movl
movul
movlg
movne
move
movue
movge
movuge
movle
movule
movo
%fccn,reg_or_imm11,regrd
Move always
Move never
Move if unordered
Move if greater
Move if less
Move if not equal
Move if equal
Move if ordered
1
0
U
G
G or U
L
L or U
L or G
L or G or U
E E or U
E or G
E or G or U
E or L
E or L or u
E or L or G
MOVRZ
MOVRLEZ
MOVRLZ
MOVRNZ
MOVRGZ
MOVRGEZ
movre
movrlez
movrlz
movrnz
movrgz
movrgez
regrs1, reg_or_imm10,regrd
(Move register on register cc)
Move if register less than or equal to zero
Z
N or Z
N
not Z
N nor Z
not N
MULX
mulx
regrs1, reg_or_imm,regrd
(Generic 64-bit Multiply) Multiply (signed or unsigned)
See SDIVX and UDIVX
POPC
popc
reg_or_imm, regrd
Population count
PREFETCH
PREFETCHA
prefetch
prefetcha
prefetcha
[address], prefetch_dcn [regaddr] imm_asi, prefetch_fcn [reg_plus_imm] %asi, prefetch_fcn
Prefetch data
Prefetch data from alternate space
See The SPARC architecture manual, version 9
SDIVX
sdivx
(64-bit signed divide) Signed Divide
See MULX and UDIVX
STX
STXA
STXFSR
stx
stxa
stxa
stx
regrd, [address]
regrd, [address] imm_asi
regrd, [reg_plus_imm] %asi %fsr, [address]
Store extended word
Store extended word into alternate space
Store floating-point register (all 64-bits)
UDIVX
udivx
regrs1, reg_or_imm, regrd
(64-bit unsigned divide) Unsigned divide
See MULX and SDIVX
E.4 SPARC-V9 Floating-Point Instruction Set Mapping
SPARC-V9 floating-point instructions are shown in the following table.
Table E–11
SPARC
Mnemonic [Types of Operands are denoted by the following lower-case letters:i 32-bit integerx 64-bit integers singled doubleq quad]
Argument List
Description
F[sdq]TOx
fstox
fdtox
fqtox
fregrs2, fregrd
fregrs2, fregrd
fregrs2, fregrd
Convert floating point to 64-bit integer
fstoi
fdtoi
fqtoi
fregrs2, fregrd
fregrs2, fregrd
fregrs2, fregrd
Convert floating-point to 32-bit integer
FxTO[sdq]
fxtos
fxtod
fxtoq
fregrs2, fregrd
fregrs2, fregrd
fregrs2, fregrd
Convert 64-bit integer to floating point
fitos
fitod
fitoq
fregrs2, fregrd
fregrs2, fregrd
fregrs2, fregrd
Convert 32-bit integer to floating point
FMOV[dq]
fmovd
fmovq
fregrs2, fregrd
fregrs2, fregrd
Move double
Move quad
FNEG[dq]
fnegd
fnegq
fregrs2, fregrd
fregrs2, fregrd
Negate double
Negate quad
FABS[dq]
fabsd
fabsq
fregrs2, fregrd
fregrs2, fregrd
Absolute value double
Absolute value quad
LDFA
LDDFA
LDQFA
lda
lda
ldda
ldda
ldqa
ldqa
[regaddr] imm_asi, fregrd
[reg_plus_imm] %asi, fregrd
Load floating-point register from alternate space
Load double floating-point register from alternate space.
Load quad floating-point register from alternate space
STFA
STDFA
STQFA
sta
sta
stda
stda
stqa
stqa
fregrd, [regaddr] imm_asi
fregrd, [reg_plus_imm] %asi
Store floating-point register to alternate space
Store double floating-point register to alternate space
Store quad floating-point register to alternate space
E.5 SPARC-V9 Synthetic Instruction-Set Mapping
Here is a mapping of synthetic instructions to hardware equivalent instructions.
Table E–12
Hardware Equivalent(s)
Comment
cas
casl
casx
casxl
[regrsl], regrs2, regrd
casa
casa
casxa
casxa
[regrsl]ASI_P, regrs2, regrd
[regrsl]ASI_P_L, regrs2, regrd
Compare & swap (cas)
cas little-endian
cas extended
cas little-endian, extended
clrx
[address]
stx
%g0, [address]
Clear extended word
clruw
clruw
regrs1, regrd
regrd
srl
srl
regrs1, %g0, regrd
regrd, %g0, regrd
Copy and clear upper word
Clear upper word
iprefetch
label
bn, pt
%xcc, label
Instruction prefetch,
mov
mov
mov
%y, regrd
%asrn, regrd
reg_or_imm, %asrn
rd
rd
wr
%y, regrd
%asrn, regrd
%g0, reg_or_imm, %asrn
ret
retl
jmpl
jmpl
%i7+8, %g0
%o7+8, %g0
Return from subroutine
Return from leaf subroutine
setn
value, r1, r2
for -xarch=v9 same as setx value r1, r2
for -xarch=v8 same as set value r2
setnhi
value, r1, r2
for -xarch=v9 same as setxhi value r1, r2
for -xarch=v8 same as sethi value r2
setuw
value,regrd
sethi
or
sethi
or
%hi(value), regrd
%g0, value, regrd
%hi(value), regrd;
regrd, %lo(value), regrd
(value & 3FF16)==0
when 0 ≤ value 4095
(otherwise)
Do not use setuw in a DCTI delay slot.
setsw
value,regrd
sethi
or
sethi
sra
sethi
or
sethi
or
sra
%hi(value), regrd
%g0, value, regrd
%hi(value), regrd
regrd, %g0, regrd
%hi(value), regrd;
%hi(value), regrd;
regrd, %g0, regrd
value>=0 and (value & 3FF16)==0
-4096 ≤ value ≤ 4095
if (value<0) and ((value & 3FF)==0)
(otherwise, if value>=0)
(otherwise, if value<0)
Do not use setsw in a CTI delay slot.
setx
value, r1, r2
sethi
or
sethi
or
sllx
or
%hh(value), r1
r1, %hm(value), r1
%lm(value), r2
r2, %lo(value), r2
r1, 32, r1
r1, r2, r2
setxhi
value r1, r2
sethi
or
sethi
sllx
or
%hh(value), r1
r1, %hm(value), r1
%lm(value), r2
r1, 32, r1
r1, r2, r2
signx
signx
regrsl, regrd
regrd
sra
sra
regrsl, %g0, regrd
regrd, %g0, regrd
Sign-extend 32-bit value to 64 bits
E.6 UltraSPARC and VIS Instruction Set Extensions
This section describes extensions that require SPARC-V9. The extensions support enhanced graphics functionality and improved memory access efficiency.
Note –
SPARC-V9 instruction set extensions used in executables may not be portable to other SPARC-V9 systems.
E.6.1 Graphics Data Formats
The overhead of converting to and from floating-point arithmetic is high, so the graphics instructions are optimized for short-integer arithmetic. Image components are 8 or 16 bits. Intermediate results are 16 or 32 bits.
E.6.2 Eight-bit Format
A 32-bit word contains pixels of four unsigned 8-bit integers. The integers represent image intensity values (Graphic, G, B, R). Support is provided for band interleaved images (store color components of a point), and band sequential images (store all values of one color component).
E.6.3 Fixed Data Formats
A 64-bit word contains four 16-bit signed fixed-point values. This is the fixed 16-bit data format.
A 64-bit word contains two 8-bit signed fixed-point values. This is the fixed 32-bit data format.
Enough precision and dynamic range (for filtering and simple image computations on pixel values) can be provided by an intermediate format of fixed data values. Pixel multiplication is used to convert from pixel data to fixed data. Pack instructions are used to convert from fixed data to pixel data (clip and truncate to an 8-bit unsigned value). The FPACKFIX instruction supports conversion from 32-bit fixed to 16-bit fixed. Rounding is done by adding one to the rounding bit position. You should use floating-point data to perform complex calculations needing more precision or dynamic range.
E.6.4 SHUTDOWN Instruction
All outstanding transactions are completed before the SHUTDOWN instruction completes.
Table E–13
SPARC
Mnemonic
Argument List
Description
SHUTDOWN
shutdown
shutdown to enter power down mode
E.6.5 Graphics Status Register (GSR)
You use ASR 0x13 instructions RDASR and WRASR to access the Graphics Status Register.
Table E–14
SPARC
Mnemonic
Argument List
Description
RDASR
WRASR
rdasr
wrasr
%gsr, regrd
regrs1, reg_or_imm, %gsr
read GSR
write GSR
E.6.6 Graphics Instructions
Unless otherwise specified, floating-point registers contain all instruction operands. There are 32 double-precision registers. Single-precision floating-point registers contain the pixel values, and double-precision floating-point registers contain the fixed values.
The opcode space reserved for the Implementation-Dependent Instruction1 (IMPDEP1) instructions is where the graphics instruction set is mapped.
Partitioned add/subtract instructions perform two 32-bit or four 16-bit partitioned adds or subtracts between the source operands corresponding fixed point values.
Table E–15
SPARC
Mnemonic
Argument List
Description
FPADD16
FPADD16S
FPADD32
FPADD32S
FPSUB16
FPSUB16S
FPSUB32
FPSUB32S
fpadd16
fpadd16s
fpadd32
fpadd32s
fpsub16
fpsub16s
fpsub32
fpsub32s
fregrs1, fregrs2, fregrd
four 16-bit add
two 16-bit add
two 32-bit add
one 32-bit add
four 16-bit subtract
two 16-bit subtract
two 32-bit subtract
one 32-bit subtract
Pack instructions convert to a lower pixel or precision fixed format.
Table E–16
SPARC
Mnemonic
Argument List
Description
FPACK16
FPACK32
FPACKFIX
FEXPAND
FPMERGE
fpack16
fpack32
fpackfix
fexpand
fpmerge
fregrs2, fregrd
fregrs2, fregrd
fregrs2, fregrd
four 16-bit packs
two 32-bit packs
four 16-bit packs
four 16-bit expands
two 32-bit merges
Partitioned multiply instructions have the following variations.
Table E–17
SPARC
Mnemonic
Argument List
Description
FMUL8x16
FMUL8x16AU
FMUL8x16AL
FMUL8SUx16
FMUL8ULx16
FMULD8SUx16
FMULD8ULx16
fmul8x16
fmul8x16au
fmul8x16al
fmul8sux16
fmul8ulx16
fmuld8sux16
fmuld8ulx16
8x16-bit partition
8x16-bit upper Graphic partition
8x16-bit lower Graphic partition
upper 8x16-bit partition
lower unsigned 8x16-bit partition
Alignment instructions have the following variations.
Table E–18
SPARC
Mnemonic
Argument List
Description
ALIGNADDRESS
ALIGNADDRESS_LITTLE
FALIGNDATA
alignaddr
alignaddrl
faligndata
regrs1, regrs2, regrd
find misaligned data access address
same as above, but little-endian
do misaligned data, data alignment
Logical operate instructions perform one of sixteen 64-bit logical operations between rs1 and rs2 (in the standard 64-bit version).
Table E–19
SPARC
Mnemonic
Argument List
Description
FZERO
FZEROS
FONE
FONES
FSRC1
fzero
fzeros
fone
fones
fsrc1
fregrd
fregrd
fregrd
fregrd
fregrs1, fregrd
zero fill
zero fill, single precision
one fill
one fill, single precision
copy src1
FSRC1S
FSRC2
FSRC2S
FNOT1
FNOT1S
fsrc1s
fsrc2
fsrc2s
fnot1
fnot1s
fregrs1, fregrd
fregrs2, fregrd
fregrs2, fregrd
fregrs1, fregrd
fregrs1, fregrd
copy src1, single precision
copy src2
copy src2, single precision
negate src1, 1's complement
same as above, single precision
FNOT2
FNOT2S
FOR
FORS
FNOR
fnot2
fnot2s
for
fors
fnor
fregrs2, fregrd
fregrs2, fregrd
negate src2, 1's complement
logical OR
logical OR, single precision
logical NOR
FNORS
FAND
FANDS
FNAND
FNANDS
fnors
fand
fands
fnand
fnands
logical NOR, single precision
logical AND
logical AND, single precision
logical NAND
logical NAND, single precision
FXOR
FXORS
FXNOR
FXNORS
FORNOT1
fxor
fxors
fxnor
fxnors
fornot1
logical XOR
logical XOR, single precision
logical XNOR
logical XNOR, single precision
negated src1 OR src2
FORNOT1S
FORNOT2
FORNOT2S
FANDNOT1
fornot1s
fornot2
fornot2s
fandnot1
src1 OR negated src2
negated src1 AND src2
FANDNOT1S
FANDNOT2
FANDNOT2S
fandnot1s
fandnot2
fandnot2s
src1 AND negated src2
Pixel compare instructions compare fixed-point values in rs1 and rs2 (two 32 bit or four 16 bit)
Table E–20
SPARC
Mnemonic
Argument List
Description
FCMPGT16
FCMPGT32
FCMPLE16
FCMPLE32
fcmpgt16
fcmpgt32
fcmple16
fcmple32
fregrs1, fregrs2, regrd
4 16-bit compare, set rd if src1>src2
2 32-bit compare, set rd if src1>src2
4 16-bit compare, set rd if src1≤src2
2 32-bit compare, set rd if src1≤src2
FCMPNE16
FCMPNE32
FCMPEQ16
FCMPEQ32
fcmpne16
fcmpne32
fcmpeq16
fcmpeq32
4 16-bit compare, set rd if src1≠src2
2 32-bit compare, set rd if src1≠src2
4 16-bit compare, set rd if src1=src2
2 32-bit compare, set rd if src1=src2
Edge handling instructions handle the boundary conditions for parallel pixel scan line loops.
Table E–21
SPARC
Mnemonic
Argument List
Description
EDGE8
EDGE8L
EDGE16
edge8
edge8l
edge16
8 8-bit edge boundary processing
same as above, little-endian
4 16-bit edge boundary processing
EDGE16L
EDGE32
EDGE32L
edge16l
edge32
edge32l
2 32-bit edge boundary processing
Pixel component distance instructions are used for motion estimation in video compression algorithms.
Table E–22
SPARC
Mnemonic
Argument List
Description
PDIST
pdist
8 8-bit components, distance between
The three-dimensional array addressing instructions convert three- dimensional fixed-point addresses (in rs1) to a blocked-byte address. The result is stored in rd.
Table E–23
SPARC
Mnemonic
Argument List
Description
ARRAY8
ARRAY16
ARRAY32
array8
array16
array32
convert 8-bit 3-D address to blocked byte address
same as above, but 16-bit
same as above, but 32-bit
E.6.7 Memory Access Instructions
These memory access instructions are part of the SPARC-V9 instruction set extensions.
Table E–24
SPARC
imm_asi
Argument List
Description
STDFA
STDFA
STDFA
STDFA
ASI_PST8_P
ASI_PST8_S
ASI_PST8_PL
ASI_PST8_SL
stda fregrd, [fregrs1] regmask, imm_asi
eight 8-bit conditional stores to:
primary address space
secondary address space
primary address space, little endian
secondary address space, little endian
STDFA
STDFA
STDFA
STDFA
ASI_PST16_P
ASI_PST16_S
ASI_PST16_PL
ASI_PST16_SL
four 16-bit conditional stores to:
STDFA
STDFA
STDFA
STDFA
ASI_PST32_P
ASI_PST32_S
ASI_PST32_PL
ASI_PST32_SL
two 32-bit conditional stores to:
Note –
To select a partial store instruction, use one of the partial store ASIs with the STDA instruction.
Table E–25
SPARC
imm_asi
Argument List
Description
LDDFA
STDFA
ASI_FL8_P
ldda [reg_addr] imm_asi, freqrd
stda freqrd, [reg_addr] imm_asi
8-bit load/store from/to:
LDDFA
STDFA
ASI_FL8_S
ldda [reg_plus_imm] %asi, freqrd
stda [reg_plus_imm] %asi
LDDFA
STDFA
ASI_FL8_PL
LDDFA
STDFA
ASI_FL8_SL
LDDFA
STDFA
ASI_FL16_P
16-bit load/store from/to:
LDDFA
STDFA
ASI_FL16_S
LDDFA
STDFA
ASI_FL16_PL
LDDFA
STDFA
ASI_FL16_SL
Note –
To select a short floating-point load and store instruction, use one of the short ASIs with the LDDA and STDA instructions.
Table E–26
SPARC
imm_asi
Argument List
Description
LDDA
LDDA
ASI_NUCLEUS_QUAD_LDD
ASI_NUCLEUS_QUAD_LDD_L
[reg_addr] imm_asi, regrd
128-bit atomic load
128-bit atomic load, little endian
LDDFA
STDFA
ASI_BLK_AIUP
64-byte block load/store from/to:
primary address space, user privilege
LDDFA
STDFA
ASI_BLK_AIUS
stda fregrd, [reg_plus_imm] %asi
secondary address space, user privilege.
LDDFA
STDFA
ASI_BLK_AIUPL
primary address space, user privilege, little endian
LDDFA
STDFA
ASI_BLK_AIUSL
secondary address space, user privilege little endian
LDDFA
STDFA
ASI_BLK_P
LDDFA
STDFA
ASI_BLK_S
LDDFA
STDFA
ASI_BLK_PL
LDDFA
STDFA
ASI_BLK_SL
LDDFA
STDFA
ASI_BLK_COMMIT_P
64-byte block commit store to primary address space
LDDFA
STDFA
ASI_BLK_COMMIT_S
64-byte block commit store to secondary address space
Note –
To select a block load and store instruction, use one of the block transfer ASIs with the LDDA and STDA instructions.
